Thread: 2 problems
    Regular Member neilb1's Avatar
    Feb 2011
    wigan
    Default 2 problems
    Doing a car service next week on a mates car 1.9 cdti think it is a 54 plate and the heater only blows cold the temp stays on min and does not move. I am to believe that this is the thermostat problem before i order one
    The second problem is that the aux belt tensioner make a noise and is it this one from e bay ppl
    http://cgi.ebay.co.uk/Vauxhall-Vectr...#ht_1058wt_905
    Oct 2008
    Trim : leather
    Engine : 2.2 d
    Year : 2013
    It sounds like the thermostat thats at fault, but check and see if both heater hoses that go into the bulkhead are hot, if they are it could be a problem with the air blend flap or its linkage inside the heater box. The tensioner in the link will not fit the 1.9 cdti models, its for the 2.0/2.2 litre diesel engines
    Aug 2006
    Is a very naughty boy
    another way to see if it is the thermostat is that if the car is left to idle then the temp will rise until the fans cut in as there is no air flow over the rad to cool it. This would then give you hot air through the heater.
    Feb 2011
    wigan
    no done this and nothing the temp guage does not move and it still blows cold all the time even after a good run the pipes were cold as well
    Aug 2010
    Leeds
    Replace your thermostat likley stuck open & when removed see if it is.
    Feb 2011
    wigan
    cheers
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 12th November 2019, 09:21
  2. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  3. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
