Thread: Oil Level Indicator (Dip Stick)
    Regular Member denzo's Avatar
    Runcorn
    Default Oil Level Indicator (Dip Stick)
    Has anybody had their Dip Stick Changed ?
    Field Remedy 1804 indicates that Dip Stick Part No: 55188282 should be changed with Part number 55200224 because of an issue.
    Does anyone know what the issue is and whether it is worth changing the dip stick?
    Mine still has original 55188282 Dip Stick
    Yes, Paul (Leeds Vectra) had his changed I'm sure although his was a 2.2 petrol (not direct iirc).
    I'll dig out that FR for you...
    Here's a PDF that relates to a dipstick issue. It is for the 2.2 (non-direct). I can't find any FR numbered 1804.
    Can't see any other dipstick issues.
    And thinking about it, it wasn't Paul that had a new dipstick, he just had a Vx dipstick overfill his engine!!
    But there definitely was someone who had this issue and had it changed. Can't remember who - have a feeling it was on another forum.
    Runcorn
    Field Remedy: 1804
    Subject: Engine Z19DT/Z19DTH - Oil level indicator comes up too early
    Models: Engines: Option:
    Signum 2004...2005,Vectra-C 2004...2005,Astra-H 2005 Z19DT| Z19DTH,Z19DT| Z19DTH,Z19DT| Z19DTH
    Complaint: Oil level indicator comes up too early although measurement with oil dipstick is OK.
    Cause: Mismatch between oil level indicator and oil dipstick due to insufficient oil dipstick design.
    Production: Introduction of new oil dipstick in production as of the following VIN's: Rüsselsheim: W0L0ZCF6851009215 (20.09.2004), Antwerp: W0L0AHL3555031383 (24.09.2004), Bochum: W0L0AHL3552031550 (29.09.2004), Ellesmereport: W0L0AHL4858019063 (29.09.2004).
    Remedy:
    In case of customer complaint replace oil dipstick against a modified one.
    New partnumber / catalognumber as follows: 55200224 / 06 58 101.
    FunctionalGroup: J - Engine
    Complaint Group: 23 - Wrong Indication
    Trouble Code: None
    Runcorn
    Dipstick anyone ? especially 1.9CDTi
    North east HQ
    who you calling a dipstick
    SOUTH SHIELDS
    does this mean i need my dipstick changing 2004 1.9 cdti 120
    Quote Originally Posted by denzo
    Looks like you answered your own question with your Field Remedy post Denzo.
    You probably want to get a new dipstick, may as well as it will be free, otherwise your dipstick will show that you have enough oil, when in fact you haven't.
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2017, 14:42
  2. Do you get any stick?
    By Juego in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 17:51
  3. Oil level gsi .
    By peter-gsi in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 15:52
  4. Will this stick fit?
    By John LE in forum Diesel Engine related
    Last Post: 6th November 2009, 01:36
  5. A.level
    By padawun in forum General Chat
    Last Post: 26th September 2006, 22:35
vectra 1.9cdti original oil dipstick
vauxhall parts 55200224
