Results 1 to 10 of 14
Thread: Rear Electrics
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Default Rear Electrics
    Evening all,
    Bit of strange one... My rear left indicator is permanently on even when the car is off. Also comes up on bulb warning as does rear left light but that isnt on or working. However bulb is fine. If i plug the other rear right side bulb holder into the left side the reverse and tail light stay on. All bulbs swapped and working, so its not a bulb.
    Here are the faults after being read.
    Source Address: REC
    Source Address: 0x00000254
    Identifier: 0x0102
    VIN: W0L0ZCF6838072060
    Part Number:13142520
    Software version number: 000003EE
    System name: REC
    System description: LEAR 0400
    Alpha code: BJ
    Number of stored fault codes: 3
    B0530 - Rear Left Turn Indicator Circuit Open
    (04) - Present
    B3881 - Rear Left Tail Light Circuit Open
    (04) - Present
    B3803 - Comfort Closing Low Voltage or Circuit Open
    (06) - Present
    Any help would be appreciated.
    Sep 2010
    yorkshire
    havent swaped any bulbs lately have you and used the single instead of a double filament or visa versa ?
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    5 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    Looks like a faulty REC [rear electrical centre] mounted in the inner n/s/r 1/4 panel, have had it when the reverse lights come on, on there own!!!. You,ve not tried wiring in any extra lighting in to the rear lights???? as this can damage the REC circuits within it.......
    Nov 2007
    Quote Originally Posted by omega63 View Post
    Only thing i have wired extra to that light is reverse sensors. They have been in for a year or so now. Also had a genuine vx towbar fitted a year ago by vx. I had the car through the hand jet wash place the other day could this have shorted anything?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    What towing electrics do you have steve?
    Nov 2007
    Both 12s and 12n
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Sorry mate, are they genuine VX ones or are they fitted with an aftermarket relay
    Nov 2007
    No genuine vx, fitted by vx themselves
    Nov 2007
    Could it be the relay do you think? One of the 10amp fuses next to the relay for towing elecs had blown... not a fuse on the fuse box but an extra fitted one.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Try disconnecting the trailer module mate, might not cure anything but nothing ventured nothing gained
  1. Rear rec unit and tow bar electrics
    By alex m in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2012, 19:34
  2. Rear door electrics
    By John2360 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 23:13
  3. rear electrics
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 18:45
  4. Started fitting my rear electrics today
    By Ian-Highlander in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2008, 20:55
  5. rear electrics? what am i doing wrong?
    By blue estate in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2008, 20:47
