Results 1 to 10 of 15
Thread: coolant bubbling from expansion tank 1.8LS 112k
    Feb 2011
    Belfast
    Default coolant bubbling from expansion tank 1.8LS 112k
    Just had thermostat replaced collected car today.
    Driving in traffic temperature guage goes to 85-90 i go onto motorway and its drops to about 70-80 normal?
    Before i got thermostat done the temperature would drop right down so it definatley needed fixed.
    BAck in traffic for 15 mins i seen steam comming from under bonnet,opened it up and the coolant was bubbling from the expansion tank,coolant low level light came on dashboard.
    Left the car sitting and checked it after 15 mins and the coolant level was low.
    This car is doing my head in
    Tony
    Regular Member wallace78's Avatar
    Dec 2010
    belfast
    who ever rplaced it might not hav bleed it!!!!
    Feb 2011
    Belfast
    This happened also with the faulty thermostat a few times also, i thought replacing the thermostat would have solved it.
    Sorry as i am clueless aboit cars
    Feb 2011
    Belfast
    Guys has my head gasket blown if the coolnat is bubling in the tank???
    If so how much for a head gasket job?
    IS it worth getting done?
    What are the odds of it failing again i ask as i got one done before on a megane and it was a waste of money blew again less than 1 week.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    If the head is fine, the gasket shouldn't blow again any time soon
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    check the expansion tank and the top for minor cracks, i had a simlar issue on my omega and a new tank and top was the fix for this
    hth
    Midlands Mod Shop - NFFC.
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    check the cap is on correct, and tight, sounds silly, but they arent the best manufactured parts in the world, the tanks are notorious for leaks and splitting, and the threads do have a little play in them.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Quote Originally Posted by ditchp View Post
    hth
    They do seem to be prone to splitting, you may have to remove it and give it a good clean to find the split. If it is split don't worry they are only around £20 from the dealers for a new one.
    Only way to test properly for a blown head is to have a sniff test done on the expansion tank. Im assuming you've checked for water in the oil, oil in the water?
    Feb 2011
    Belfast
    Yes mate checked the oil seems ok not milky its clean oil just had it serviced.
    Thanks i will chcek out a new tank seems best to start with the cheapest option.
    I have to get it to vauxhall as i still have a problem with my immobliser the light comes on and the car wont start , when iturn the key from position 1 to position 2 i get a the car and pad lock symbol,also i hear a clicking noise comming from part of the engine that looks like where there is a big scart lead pluged into some unit.'
    Im hopping that reprogramming the key or a new transponder will fix this.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    As Dasarab said,oil and water won't neccesarily show up a head gasket, a sniff test on the header tank will. Fingers crossed it's something simple.
  1. Promotasport alloy coolant expansion tank
    By Kev_A in forum Quick Photo Album
    Last Post: 2nd September 2012, 17:24
  2. Coolant Expansion Tank
    By Telboy in forum Engine & Drivetrain
    Last Post: 2nd May 2011, 21:11
  3. water in header tank bubbling....why ?
    By manimal in forum Engine & Drivetrain
    Last Post: 28th September 2010, 18:41
  4. expansion tank
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2010, 21:25
  5. Expansion tank cap!
    By MadOnVaux! in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2010, 17:51
insignia coolant boiling
vectra coolant tank boiling
1.8 vectra bubbling
bubbling water tank vauxhall zafira 1.6 2010
corsa d coolant boiling
zafira b bubbles in header tank
Zafira 1.8 Boiling water
why does my coolant on my insignia bubble
location of vectra c coolant expansion tank
1.8 insignia cooling system
vauxhall corsa coolant bubbling
vectra c 1.8 coolant boiling
coolant bubbling vectra
vectra c expansion tank boiling
vectra c coolant boiling
vauxhall insignia coolant boiling
vectra c expansion tank bubbling
vauxhall astra cooling tank boiling up
https:www.vectra-c.comforumshowthread.php131452-coolant-bubbling-from-expansion-tank-1-8LS-112k
2011 vauxhall zafira coolant bubbling
zafira b 1.6 petrol water boiling out of bottle
