Results 1 to 10 of 30
Thread: 2.0t turbo/cat/exhaust manifold noise
    Regular Member rockhopper's Avatar
    Scotland
    Default 2.0t turbo/cat/exhaust manifold noise
    Hi. Car running absolutely fine yesterday. On the drive to work this morning I norice the turbo whine is louder than normal, no noticeable performance difference.
    On way home the turbo noise slightly louder and a bit more 'farty' from under the bonnet when under full load but very refined otherwise. The turbo is definately more audible more of the time now though. Maybe very slightly less powerful. Had a quick listen under the bonnet and it definately sounds like a crack/hole in the exhaust from the turbo area.
    I've had a search on here and found threads suggesting the bolts on the cat coming loose and tbh I'm hoping that's all it is. I'm going to have a good look tomorrow up on ramps, any specific suggestions on where to look and what for?
    Regular Member mann3210's Avatar
    scotland, perth
    if it is just loose nuts id get a gasket from dingbro as youve prob missed the vauxhall next day delivery or vor, check the turbo pipes, 1 might be split or loose
    Scotland
    Thanks. It was nagging me too much so I went out and took the turbo heat shield off for a look. In the picture you can see bolts in the centre, to the left of the sensor (sorry not too good with the technical names). There are only two and the top one was about to fall off. The third, as you can see, is totally missing so I'm assuming this is the problem. I tightened up the top one and it seems to have made a difference, perhaps the bottom one has been missing for a while. I hope this is it. Does anyone know the dimension of the bolts so I can go get one, or maybe the part numbers? Thanks again.
    scotland, perth
    bingo, take it to your local vx dealer grab a parts advisor they should sort that out for you, id get a couple just as spares!
    Scotland
    Brilliant cheers. I believe my local vx dealer might also be your local vx dealer, I recognise your car. Infact, I think you live just round the corner from me. v.nice car! Is there a technical name for the bolts that I can give to the parts advisor?
    Hopefully that's it. Although I've just found one of my exhaust back box heat shields hanging off too. And they say bad things come in 3's......
    scotland, perth
    you on the other side of west mains avenue from me with the limited edition 2.0T? cracking motor mate, if you go to peter vardy before 12, they will come out & see what you need, i deal with them every day & there knowledge is spot on, when you go in say james (me) @ john martin sent you & want looked after, they should keep you right , let me know how you get on
    Regular Member Jezzy's Avatar
    S.E
    The bolt you need is an M8, described as M8x38, so maybe that means it's 38mm in length. Part number 90490326, and they come as a pack of three.
    scotland, perth
    there you go bud sorted, jezzy your the man when it comes to part numbers! you got a vx epc at home?
    S.E
    lol
    Scotland
    can't thank you guys enough. won't make it to the dealership before 12 due to work but will go in on monday. thanks again
  1. Snapped exhaust manifold/turbo stud snapped in cylinder head!
    By XPCobra in forum Engine & Drivetrain
    Last Post: 7th May 2012, 10:50
  2. vectra sri turbo manifold gasket
    By robsriturbo in forum Engine & Drivetrain
    Last Post: 9th June 2010, 16:55
  3. Exhaust Manifold for 1.8 VVT
    By Gray16v in forum Petrol Engine related
    Last Post: 23rd December 2009, 23:34
  4. exhaust manifold
    By KeefyB in forum Petrol Engine related
    Last Post: 19th September 2009, 22:01
  5. Inlet & Exhaust manifold
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2006, 15:15
z20net exhaust manifold noise
z20net exhaust manifold cracked
vectra c cat noise
