Results 1 to 2 of 2
Thread: Power Steering pump failure
    Default Power Steering pump failure - code needed?
    Hi all,
    I've been having intermitent power steering failure. My local garage have checked the unit and said that it is faulty. I've managed to get a second hand unit of an 07 plate, mine's a 53.
    Does the garage have to recode the new pump? They're saying that their equipment (which isn't Tech 2) is showing no fault readings (it did on the original pump) but the new pump wont work.
    Any ideas/solutions would be gratefully received.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    When you replace electro-Hydraulic supply unit you have to program e-H control unit with Tech2
  1. Power Steering Failure
    By MadOnVaux! in forum Suspension, Wheels & Brakes
    Last Post: 17th December 2011, 23:40
  2. Power Steering Failure
    By derrybulmers in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 20:10
  3. Power steering failure
    By Chris06v6 in forum Engine & Drivetrain
    Last Post: 28th July 2011, 06:22
  4. Power Steering Failure
    By gsi.vxr in forum Engine & Drivetrain
    Last Post: 26th October 2010, 15:01
  5. Power steering failure???
    By PeterVV in forum Vectra C / Signum Troubleshooting
    Last Post: 7th October 2010, 06:37
