Results 1 to 3 of 3
Thread: Fault Code P0621-01 - Generator Lamp....
    Nov 2010
    East Midlands
    Trim : design
    Default Fault Code P0621-01 - Generator Lamp....
    Hi, Just had a check done on my 04 1.9cdti and it came up with the following fault code - P0621 - 01 Generator Lamp "L" Control Circuit Malfunction - Any one have any idea what this may be - I recently changed the alternator and I think the battery may be on the way out now - could these be connected. Cleared the fault but re checked and its back again,
    Nov 2010
    East Midlands
    Trim : design
    bump
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Faulty alternator... Someone else had the same problem only a few days ago
  1. Replies: 6
    Last Post: 18th November 2012, 17:22
  2. 3.2 fault code 10-3
    By ip8645 in forum Engine & Drivetrain
    Last Post: 6th August 2012, 21:33
  3. P0621 - Generator Lamp "L" Control Circuit Malfunction
    By danielk in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2012, 20:57
  4. fault code
    By mvl41183 in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2012, 22:26
  5. Fault warning lamp
    By David2452 in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2006, 21:55
p0621 vectra
p0621 vauxhall
vectra c generator warning lamp fault
zafira b code p0621
https:www.vectra-c.comforumshowthread.php131436-Fault-Code-P0621-01-Generator-Lamp
p0621-01 vectra
Vauxhall DTC P0621-04
p0621 04
Opel DTC P0621-04
vectra c 0621
p0621-01 vauxhall zafira
Generator Lamp L Control Circuit Malfunction
p0621 fault code
vectra c p0621
p0621-01
OPEL P0621
zafira fault code p0621-01
p0621-03 vectra
opel vectra c fault code 0621
opel vectra c 1.9 cdti код ошибки p0621
p0621 vectra c
p0621vauxhall
vauxhall fault code 0621
p0621-01 2005
opel p0621-01
