Results 1 to 10 of 14
Thread: Ammonia Smell In Cabin
    Regular Member PORKBALLS29's Avatar
    Epping
    Default Ammonia Smell In Cabin
    Hi all,
    Since the rolling road last Sunday, I've had a strange ammonia smell in the cabin of the Siggy. I've had the heaters on full blast and smelt the air coming through and it isn't from them. I've checked under the hood and ther are no pipes loose or split and no fluid leaking anywhere. I smelt it straight after the car was on the rollers and it has not gone since. Any body got any ideas?
    Howard
    Full Member Big Sig's Avatar
    I get that from my car, but only when its been thrashed for a while and the cats get really hot. Although when it cools down its gone.
    Not got a cat do you???
    Aug 2010
    Leeds
    Oil leaks onto hot exhaust pipes or manifolds stink & so does coolant loss on the same parts.
    On the rollers it was pushed and took to max so you may have now got a slight leak worth another look?
    Didn't the 2.8t's have a rework for the header tank splitting?
    WGAF#5
    yup but Howards has already had this fitted
    Ah well, worth posting up though
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Had any old people in the car?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Knowing what im like at rolling roads, did you have an accident watching your car on the rollers?
    Epping
    Quote Originally Posted by s_zigmond View Post
    No, just when I got my figures, I'm thinking it must be coolant as it smells that way. But cant see where its coming from at all.
    Aug 2010
    Leeds
    Quote Originally Posted by PORKBALLS29 View Post
    Radiator hose or metal pipe work under pressure may spray onto a manifold or exhaust when pushed hard.
    A coolant pressure test will show this up easy.
    Look at your coolant the colour and can you shine a torch around and see this anywhere on the block or bodywork?
    Oil also stinks and can be confusing again any oil leaks even slight ones can stink on something very hot.
  1. Eggy smell in cabin....what could cause this?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 19:38
  2. Smell in Cabin....
    By unreal_event_horizon in forum Engine & Drivetrain
    Last Post: 1st February 2011, 00:57
  3. Fumes smell in the cabin
    By Northy in forum Engine & Drivetrain
    Last Post: 17th January 2010, 19:59
  4. Cabin smell when fan on full speed
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2010, 12:09
  5. Exhaust smell inside the cabin
    By GMONSTER in forum Troubleshooting
    Last Post: 28th April 2009, 18:39
