Thread: Inlet manifold what do I need
    Regular Member sebadee's Avatar
    macclesfield
    Default Inlet manifold what do I need
    As u can probably guess my swirl valve is no longer connected well not properly anyway have done the £1 fix it is a bit better but not as it should be so just wanting to know everything I need to replace it I have a mechanic who will do it for me just need to get the parts. Also part numbers would be great if you know them have had a quick search but as I'm currently using my phone it's not to easy
    Thanks sebadee
    Nov 2010
    DORSET
    sebadee, i ordered a new manifold with gasket yesterday from vauxhall parts warehouse, they sell on ebay but i ordered mine over the phone. It arrived today 25hrs later. cost £159 plus carrage.Thier phone number:01638540018
    macclesfield
    Cheers spongebob
    macclesfield
    Probably a stupid question but would a inlet manifold from an 08 plate cdti Sri 150 fit my 04 cdti Sri 150
    macclesfield
    Bump
    Regular Member mozzer99's Avatar
    bristol
    Smile
    Yes it will - this would be the later modified one, current thinking seems to be that the modifications have worked to stop seizing and the manifold will not seize/stick.
    However as far as I'm concerned the fact that the plastic swirl flaps rotate in an alloy housing means that the problem of wear in the bearing surfaces probably won't go away and leakage of pressure will start after a certain number of miles.
    So unless the manifold is very cheap and you know it's very low mileage I would not bother with second hand unless less than £50?
    It's such a pig of a job you don't want to do it twice!
    Regular Member corderz's Avatar
    Bradford
    I agree with mozzer, just get a new one off ebay that comes with the gasket, that it pretty much all you need
    macclesfield
    Been told I can have the manifold free as dads friend just binned his sideways into a tree only 32000 miles
    bristol
    Quote Originally Posted by sebadee View Post
    Free is a good deal!
    macclesfield
    Still trying to get an answer as to how he hit the tree sideways on a straight road
  1. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  2. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  3. Inlet Manifold Done
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 12:32
  4. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
  5. New Inlet manifold?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 8th November 2009, 23:06
