Thread: P0380 - Glow Device Circuit Low Voltage
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Default P0380 - Glow Device Circuit Low Voltage
    Right, I've had a spanner on start up for over a year now.
    Got the codes read by Innes and the one thats come up is the above glow plug code.
    I've just had them checked and 1 was a dud, 1 hadn't been screwed in properly before i had the car and was just black, thread snapped and had to be drilled out and the other two were fine.
    Got the codes cleared today and low and behold the spanner is back on next start up
    Is it possible the leads could be causing the error?
    Anyone have a link for them? 52 plate 2.0 DTI
    Thanks in advance
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    I have not heard of the leads causing a problem, but i have heard of the capacitor and the relay causing problems . watch this space ben i will have a dig and get back to you
    Engine : 2.0DTi
    Mileage : 73350
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    interesting that the temp sensor might cause the glow plug error. I'll follow the leads to whereever they go tomorrow to see if anything looks like it has got caught but I really have no idea what i'm looking at!
  1. FAULT CODE HELP: p0380-08 glow device general error
    By merikiito in forum Engine & Drivetrain
    Last Post: 19th November 2011, 17:28
  2. Code p0380, how do you find faults in glow circuit?
    By Gazza36 in forum Engine & Drivetrain
    Last Post: 4th February 2011, 14:02
  3. P0380 Stored Glow Plug/Heater Circuit A Malfunction
    By frag45 in forum Engine & Drivetrain
    Last Post: 5th January 2011, 13:01
  4. P0381 Glow Device Circuit Low Voltage
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2009, 13:09
p0380-0b
p0380 glow device circuit general error
p0380-0b opel
p0380-0b glow device circuit low voltage
Glow device circuit low signal
Opel DTC P0380-0B
p0380-08 vauxhall
glow device voltage low
OPEL P0380
Opel DTC P0380-08
P0380 OPEL
грешка p0380-0B glow device low voltage
general glow device syst
Glowdevicecircuitoopen
opel p3080 fault
Glow device circuit voltage
p0380 glow device circuit low voltage
opel p0380-0b glow device circuit low voltage
po38 glow low voltage vectra c
p0380-02
vectra c glow device low voltage
Vauxhall P0380(0B)
opel glow device circuit low voltage
