Thread: ABS issue's
    Mar 2011
    Cirencester
    Default ABS issue's
    As in the ABS light is on.
    Now a bit of background, I have only had the car a short time and not long after taking posetion the light came on so i took it along to my local garage (who do all my work) and they read the code as bing the front right speed sensor. So i sourced the part and had them change it for me but the light will not reset and it is still reading the same code, c0040 They can't do anymore with it so here i am asking the experts ????
    Nottinghamshire
    C0040 - Right Front Wheel Speed Circuit Malfunction?
    Sounds like it might be worth checking the wiring and the connector under the wheelarch. The former might be damaged (look for obvious damage and things like bugles/kinks and check it's fastened into all of the brackets) and the latter might have leaked (check the pins are clean and shiny, and that the sockets haven't got water in them).
    Is the new wheel hub that they fitted genuine or aftermarket? Some of the aftermarket ones don't always work properly.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Have They Cleared The Codes ?
    Nottinghamshire
    Worth asking, but that sort of code usually clears itself as soon as whatever caused it has been fixed. The other option is to disconnect the battery negative terminal for half an hour to see if that will clear it.
    Mar 2011
    Cirencester
    Quote Originally Posted by James24 View Post
    They said they checked all the connectors and the car was still on the ramp when i went to collect and everything looked ok to me but i will unplug and check inside them tommorrow.
    There was only so much of thwe wirring i could see as it went up inside the inner wing.
    Tam, Not sure on them clearing the codes but they reset the insp servive read out ok ??? I will call and ask
    Regular Member Diesel Dude's Avatar
    Norfolk
    Once I'd repaired my abs wiring took the car for a test drive after about 1/4 mile the light reset itself.
  1. AFL Issue's
    By shan in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2012, 09:52
  2. 2.2Dti Fuel Pump issue's?
    By sigtim in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 21:48
  3. Driveshaft issue's 2.0T??
    By Steven in forum Engine & Drivetrain
    Last Post: 13th February 2008, 17:28
