Thread: how do i
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    Default how do i
    adjust the handbrake, after fitting new pads the handbrake clicks about 7 time now and only did 4 or 5 before.cheers.luke
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    It will settle down and adjust itself up properly. Im sure someone posted on her that your actually supposed to work the handbrake before pumping the foot pedal up when you change the rear pads. Anyway it will sort itself out.
    Aug 2009
    cheers for the reply mate.
    Regular Member i5aces's Avatar
    andover
    i was always told it was the other way round
    use the brakes before using the handbreak
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    You press the brake pedal to move the piston towards the pads effectively taking up the "slack" then your handbrake should be ok
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The hand brake adjusts the rear pads hence the need for the pistons to be rewound back in, fit new pads ratchet the handbrake firmly & continuisly until correct , apply footbrake, recheck handbrake.
