Results 1 to 10 of 14
Thread: New water pump?
    Regular Member connery-sri's Avatar
    Basildon, Essex
    Default New water pump?
    Afternoon all,
    While having my thermostat changed a while ago, I was advised that I had a slight 'leak' from a seal on my water pump. I was told this may result in a little bit of water in the oil.
    I left it as it was, but have recently noticed my oil getting a bit gunky, like it would be if the head had gone. I have had a chemical test done twice which said head was fine and I have had no real noticeable coolant loss or overheating.
    Do I need a new water pump? If so, how much? 03 2.2 SRI Petrol.
    Thanks in advance!!
    Basildon, Essex
    Anyone able to shed some light?
    Woodbridge
    Im not to sure where the stat is on your car, I would be interested to know how he could tell you need a new pump as it is positioned behind the cam belt, which requires engine mounting brackets to be removed to see it. (Unless im wrong, maybe the stat is there).
    Basildon, Essex
    Well I am clueless as far as engines go. Hence, I am after some advice.
    Thanks for the info.
    Woodbridge
    ok, I have just read the haynes manual for the 2.2 thermo, and it is actually located close to the water pump, So I guess he could of seen that it needed replacing. How many miles does it have on the clock?
    Basildon, Essex
    Just under 102k
    Woodbridge
    Mate, if it has never had the water pump done, I suggest you get it done. Cant remember what the schedule is for the cam chain on the 2.2. But it may be worth doing them together.
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    Its run off a chain i think and a pipe fits into it with an o ring which could be seeping
    Basildon, Essex
    Woodbridge
    From VX, not sure on the price of a chain, but it is gonna be in region of £500 for both. Just the pump, probs a little less, however to do the pump they need to get the chain off, if I recall correctly, Hopefully someone with a bit more knowledge of a 2.2 will pop up soon.
  1. water pump
    By GCusdin in forum Engine & Drivetrain
    Last Post: 7th March 2013, 21:16
  2. Water pump.
    By Kenny_Exclusiv in forum Engine & Drivetrain
    Last Post: 24th September 2012, 22:19
  3. New water pump due???
    By R33Leroy in forum Engine & Drivetrain
    Last Post: 1st April 2012, 21:27
  4. Water pump
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2010, 18:55
  5. Water Pump 2.2
    By richpu in forum Engine & Drivetrain
    Last Post: 27th January 2009, 01:46
2.2 sri water pump timing chain
