Thread: Glow plugs - 120 cdti (2004) vectra
    Jul 2010
    birmingham
    Default Glow plugs - 120 cdti (2004) vectra
    Righto
    Having found the cause and ansewer to most things to do with this car on this website, I though I would try again.
    Having rached 89,000k in the car, i thought it best to have the CAM belt changed last week. Just before it was due to go in, the alternator light came on as well so this was also changed (beyond my D.I.Y skills unfortunately). Once running, the car is fine but getting it started in the morning is a pain. Its turning over, just not quite kicking in. The mechanic (who did the laternator) has said that there is a problem code for the glow plugs showing up however, I believe there is a "glow plug warning light" which I presume would be flashing like crazy if they werea ctually goosed?
    Is it worth just changing the plugs or could there be another reason?
    Cheers in advance
    Leeds
    The usual indication of a glow plug failure is for the car and spanner light to remain illuminated for 3 or 4 minutes after the car has been started from cold.
    Jul 2010
    birmingham
    ah, i have that! just thought that was the service light...righto, will change glow plugs and go from there. Wish me luck - believe the 120 is a nightmare to change plugs on!
    thanks for your help
    Jul 2010
    birmingham
    any ideas where to get cheaper ones from anyone? also - how hard is it to do?
    Engine : 1.9 CDTi
    Strange as it may seem but Vauxhall were the cheapest for good ones.
  1. 1.9 CDTI 150 Glow plugs....Help???
    By bogjust in forum Engine & Drivetrain
    Last Post: 28th January 2013, 12:20
  2. 2006 Vectra 1.9 CDTI 120hp Glow Plugs
    By Mark-Rainey in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2012, 20:34
  3. 1.9 cdti 120 glow plugs
    By big rich in forum Engine & Drivetrain
    Last Post: 10th September 2010, 13:46
  4. Glow plugs on a CDTI 120
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 5th November 2009, 22:39
