Results 1 to 2 of 2
Thread: Wipers not going full down.
    Mar 2011
    berkshire
    Default Wipers not going full down.
    Hi, my windows where frosted and i turned on wipers and it made them stop 2 inches where they should be, i had this once b4 but it went back to its original position, but this time its stuck 2 inches higher then it should be.
    Feb 2011
    Stoke on trent
    Before you adjust the wipers make sure they cannot still return to original position, by wetting the windscreen thoroughly then operate the wipers, if they still stay high, then you will have to reset the wiper arms position. With the bonnet up, using a small flat screwdriver, remove the plastic caps on top of the wiper arm shafts to expose the fastening nuts. Loosen these off ( they may be already quite loose causing the wiper arms to move on the shaft). Push up and down ( wangle) on each wiper arm to free it from the splined tapered seating. Reposition the arm to its correct place on the screen and retighten the fastening nuts. Close the bonnet and check for correct operation with the windscreen thoroughly wet. Re-adjust if necessary
  1. Wipers?
    By sriandy in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2012, 11:09
  2. Wipers not working on Full speed
    By jbrines in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2011, 15:27
  3. Replies: 3
    Last Post: 15th November 2010, 13:14
  4. Replies: 0
    Last Post: 21st July 2010, 19:11
  5. Need New Wipers-I think?
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2009, 15:17
