Results 1 to 3 of 3
Thread: Facelift headlight removal help !!
    Jan 2010
    worcs
    Default Facelift headlight removal help !!
    Hi all .
    Ive fitted a hid kit to me facelift and now the headlight keeps steaming up quite badly.
    I know its down to the fact that i havent sealed around the hole i made for the wiring, also the ballast is just resting between the airbox and the back of the light.
    what i need to do is get the light off and sort it all out.
    is there a way of removing the headlights without fully taking the front bumper off??
    ive looked in the how 2 section but it only shows a pre facelift as far as i can see.
    also do yuo have any ideas where i can put the ballasts in a more permanent place?
    cheers
    steve
    also
    Full Member spennny's Avatar
    Blantyre
    You need to remove the bumper mate, its a 10 min job
    2 torx in each inner wing
    4 torx joining to slam panel
    4 plastic rivets underneath
    Did tou cut the holes to big, if you need new covers for the lights i have some spare you can have
    WGAF#5
    the ballasts will sit in the purpose built recess under the lights where the factory ones sit - you could also try popping in a couple of sachets of silica gel to absorb the moisture in there
  1. Headlight removal
    By a6lns in forum Bodywork & Interior
    Last Post: 13th January 2013, 13:20
  2. vec facelift headlight removal
    By dobson in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2012, 18:40
  3. headlight removal
    By Tam80 in forum Bodywork & Interior
    Last Post: 4th September 2010, 07:10
  4. Headlight removal
    By stubopvectra in forum Styling
    Last Post: 21st February 2008, 21:40
  5. Facelift vectra headlight removal
    By wilf2312 in forum Bodywork & Interior
    Last Post: 5th May 2007, 15:35
