Thread: HELP Please !! Another new DMF
    Mar 2011
    manchester
    Default HELP Please !! Another new DMF
    Hi guys. New here so forgive me if I sound stupid. Only drive it, don't know anything about it really!
    Vectra 1.9 CDTI
    In January 2010 I hit a BIG pothole in the dark. Took the car into VX under warranty in April for a suspected DMF failure, which was replaced under warranty but the original clutch was re-installed. Still had 'tingling' (slight vibration) in clutch pedal which got worse. This week (March 11) I took it back to VX about the clutch vibration and they have fitted a new DMF again and a new clutch. BUT I still have the tingling/vibration in the clutch pedal. Could there be something slightly bent elsewhere that is causing this vibration?
    Can't afford to change car and I'm beginning to panic.
    Thanks guys
    Mar 2011
    berkshire
    Seem's like a bleed job to me, maybe air is trapped.
    BULFORD
    Hi matey im in salisbury and my dealership are been idiots, can you send me the branch were you had your DMF and new clutch changed as my DMF failed at 34k and changed under warrenty like you they fitted the old clutch even i said ill pay for a new one to be put in and now its back in the Andover branch now getting a new DMF but they saying that its a clutch problem
    Woodbridge
    Quote Originally Posted by jingerman View Post
    Would it not have been bleed when they fitted the new one?
