Results 1 to 10 of 14
Thread: carpets soaking
    Mar 2011
    hartlepool
    Default carpets soaking
    just bought my signum last friday, but have noticed every footwell is soaking wet i thought the bloke i bought it off must have washed the carpets, but on saturday i mopped them useing a shammy, monday tried the vac at local garage, and today used the carpet cleaner managed to get out around quater of a litre with this. i've been reading other peoples problems like this and also my heater fan only seems to work on setting 4. as some one pointed out theres a fix in "the how 2" but dont think i have enough post counts to check it out. anyone local willing to help me with this
    fozz
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    you dont need post counts in the search box put scuttle panel drain all the info is there
    Mar 2011
    hartlepool
    Quote Originally Posted by markj23 View Post
    cheers bud
    Aug 2010
    Luton
    dont be shy when sticking your finger in the hole hehe it wont bite you lol
    Blantyre
    Yeah the scuttle panel part is fine, but sounds like the resistor has blown also , if the fan is only working on setting 4 ?
    Regular Member wallace78's Avatar
    Dec 2010
    belfast
    and mke sure its pulled down in place thats wat was causing my carpets 2 b soaked!!!!
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Checking the scuttle drain and the front footwells for damp is an absolute must when buying a Vectra. My last Vectra (a Network Q purchase) had a damp passenger footwell I only discovered one month after buying the car. I now check regularly that my drain is clear by lifting the flap cut into the scuttle cover on the passenger side and checking that the area in front of the pollen filter and the rubber drain tube are both clear of water and debris.
    So easy to do at the same time as your other under-the-bonnet checks.
    Prevention is better than cure.
    Mar 2011
    hartlepool
    thanks all, done the scuttle clean only a 5 min job (was really chuffed with myself as im not mechanicly minded) the amount of crap and water that came out was unbelievable, so will this clear the wet carpets? right next bit is the fan only blowing on setting 4, i took the pollen filter out which was dry and looking at the fan motor couldnt see any rust could easily turn it by hand, sprayed wd40 to make sure no water was in there. could i use motorcycle chain lube to lube it??? so as spenny said i need a resister???? how much is this and is easy to do, thanks in advance.
    fozz
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by fozz View Post
    fozz
    There's another drain hole..see my post below in another thread...
    http://www.vectra-c.com/forum/showpo...00&postcount=7
    Aug 2010
    Luton
    fozz
    82p from Maplin RS23A is what you need then 2 small electrical connector blocks and strip all the plastic off them then read the how to its easy will take about 1 hour or 20 mins if you are mechanically minded
  1. Wet carpets!!!!! help
    By yorkiebar in forum Bodywork & Interior
    Last Post: 24th March 2011, 19:34
  2. Nearside rear floor soaking??
    By nike in forum Bodywork & Interior
    Last Post: 26th February 2011, 00:46
  3. wet carpets
    By xf8u39 in forum Bodywork & Interior
    Last Post: 1st February 2011, 09:09
  4. Best way to dry out carpets?
    By varadero in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2007, 16:22
