Thread: rear brakes
    wales
    Default rear brakes
    hi looking for a bit off help with rear brakes since owning the car for 2 years it seams to be eating rear brake shoes but only on passenger side i have put new disk and pads on it when i brought it 5 months later had to replace pads again one side worn down to metal the other looked like new . took into vaux and was told caliper was sticking so then i changed the 2 rear calipers while it was having new shoes at vaux main dealer and told this would cure it but again passenger side has worn down well before the other side getting p.... off paying for brakes every 6 months any help please think could be somthing with handbrake
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    I noticed on mine that under the rubbers where the slides slide through can get a build up of corrosion which stops the slides from sliding. This means the calipers dont move freely. You need to remove the rubbers and clean the corrosion away using sand paper. I posted a pic of this a while back, hold on while I find it.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Heres the pic of where the corrosion builds up.
    wales
    thanks m8 going into garage tommorow for new pads again will get them to look at the slides like you said thanks again
  1. need help for rear brakes
    By sharney2011 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2011, 18:20
  2. Rear brakes
    By copperdock in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 22:50
  3. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
  4. Rear brakes
    By dan1983 in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2007, 21:09
