Thread: Emissions light help!
    Regular Member LJ sxi-nav's Avatar
    Winchester
    confused Emissions light help!
    Hi all, hoping someone can help. As per a couple of recent posts on here I have had to replace the EGR valve. Well the new EGR is fitted and the car is transformed!! Drives a hell of a lot better than it did. The problem is the emissions light is staying on
    summary
    * Loss of power/lumpy running/sooty exhaust etc.
    * In order to drive it last Friday I had to disconnect the EGR, which initially threw up the EML, but the car was much more responsive! When I restarted later that day the EML light was out (as expected it was on at startup, but disappeared as soon as the car was started) but the emissions light was on (Dan_BlackSRi suggested to me this is standard behaviour). I covered approx 60miles with 2 stops, with EGR disconnected.
    * Saturday I set about cleaning the EGR, but didn't do the drilling bit on the solenoid. During cleaning car was disconnected from the battery (I had a new battery to fit anyway, so thought i'd leave it disconnected during the removal, cleaning and refitting). Car was marginally better, but the hesitation was still obvious and emissions light still on. New EGR ordered.
    * This afternoon I fitted the new EGR and standard gaskets. Car is infinitely better, but emissions light still on.
    Any idea what to check next on my 2005(55) 95k 1.9CDTI 8v [120] in order to clear the emissions light - can it be reset by tech2/generic code readers, or is it designed to only be on if there is an actual fault present? Took car on a 15 mile test drive and it drives superb. MPG seems fine (although I know that was a short journey).
    Winchester
    bump - drove to work today (~35 miles) and emissions light is still there, but car driving well and mpg is still good (av over 50 miles is 49mpg- mostly A roads and motorway).
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Try disconnecting the battery for half an hour and that may reset the light.
    Winchester
    Did that yesterday when the EGR was fitted.
    Anyway it is now SOVLED - After a further 10miles driving the emissions light is now off! guess the ECU just needed an average range of values to work out it is now OK.
  1. Emissions light
    By shuggler in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2012, 19:16
  2. emissions light
    By trickster75 in forum Engine & Drivetrain
    Last Post: 19th May 2011, 21:10
  3. Emissions Light
    By battle84555 in forum Engine & Drivetrain
    Last Post: 20th February 2011, 19:56
  4. Emissions Light
    By Frp01 in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 09:31
  5. Emissions Light
    By BigKev1970 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th September 2007, 22:16
