Results 1 to 10 of 29
Thread: Signum 3.0 V6 CDTI Cam Belt
    Regular Member juggernaut's Avatar
    Rugby
    Default Signum 3.0 V6 CDTI Cam Belt
    Hi
    Cam belt needs changing on my Signum but my mechanic friend has not done a V6 diesel before and his Autodata (up to 2004) book doesn't show it. Has anyone got up to date diagrams etc I could have copies of please?
    They are here, somewhere
    Search Y30DT cambelt :
    http://www.vectra-c.com/forum/showth...=Y30DT+cambelt (see page two)
    Ask for the cambelt kit to be fitted, and ask for the old parts back
    Just make sure the valve clearances are checked once the cambelt is replaced
    Regular Member benny's Avatar
    Feb 2006
    dudley
    pmsl @ valve clearance check ....lol......................even vx say if done at 100k correctly it would write the car off lol .,
    Regular Member themarbleman's Avatar
    sussex
    Make sure all the tensioners are replaced also. Please note that there is an additional pulley /wheel required that is not in the kit.
    Just out of interest who is doing it for you ?
    The reason i ask is that a friend of mine who i have known for 20 yrs (so he will not rip me off),could not even buy the cambelt kit as cheap as vauxhall could do the whole job !!!!!!!
    Full cambelt and interim service was £502 inc vat from Vauxhall and you get the all important stamp in your service book.
    Dont just assume that a local garage may be cheaper than the vauxhall dealer.
    Quote Originally Posted by benny View Post
    Had cambelt done on mine and no need to write the car off
    Cambelt change was paid for by VX under service component of warranty
    Dealership only wanted to replace the cambelt, but I pointed out all the additional work that was required, "oh, er, wasn't aware of that"
    During the quote they advised it would take two hours, but when I asked why the info on TIS states six hours, and they quickly changed their tune when they checked
    On completion he agreed the cambelt itself was two hours, but he still managed all that they listed in just under five hours
    Feb 2006
    dudley
    how much did they charge for a valve clearance check ? .....
    No idea as it was all paid for under the warranty policy and the invoice was cambelt renewal labour 5.0 hours
    However, it took them about an hour after the cambelt was changed
    They did the cambelt from 08:00 to 12:00, then completed the valve clearances at about 13:15 (thankfully the mechanic didn't stop for lunch at 13:00)
    Feb 2006
    dudley
    lol.....a hour to check the valve clearance ....id love to see it done in that time ....
    Oct 2010
    Lincoln
    Gotta a Veccy C V6 CDti so when should the cambelt be changed? Currently done 77K.
    Feb 2006
    dudley
    Quote Originally Posted by lencuff View Post
    i did myn at 50k ...lol....but they say about 100k ....id go for 80k ...
  1. timing belt kit CDTi
    By Derek Mc in forum Diesel Engine related
    Last Post: 19th August 2012, 16:44
  2. CDTI 150 CAM Belt again :)
    Last Post: 10th June 2012, 16:21
  3. Cam belt 1.9 CDTI 150
    By chewy71 in forum Engine & Drivetrain
    Last Post: 10th January 2012, 20:00
  4. cam belt on 3.0 CDTi
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2008, 19:53
  5. CDTi Cam Belt
    By WHOOSH05 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2007, 18:21
vectra c 3l v6 timing belt
vectra c 3.0 timing belt change
how often do you change timing belt on vauxhall vectra 3.0 v6 cdti
signum 3.0 cdti timing belt hours
how to set timing vectra c v6
2004 vauxhall signum v6 3L timing belt
vectra y30dt timing belt change
vectra 3.0 v6 change timing belt
when does cambelt signum
vectra 3.0cdt worn engine mounts
belt 3.0 cdti
vauxhall vectra 3.0 cdti timing belt change
opel signum isuzu 2004 3.0 cdti timing belt
3lt v6 diesel signum timing belt
timing belt vectra c 3.0 cdti
timming belt kit dayco signum v6 cdti
how often you reniew timming belt in signum 3.0 v6 cdti
how to change fan belt on vauxhall signum v6 cdti
v6 3l vector cam belt vauxhall
signum 3.0 cdti cambelt change
vauxhall signum v6 cdti cambelt
opel signum 3.0 v6 cdti cambelt
how do i replace cambelt on a vauxhall signum 3 litre v6 deisel
https:www.vectra-c.comforumshowthread.php131255-Signum-3-0-V6-CDTI-Cam-Belt
cambelt failure on vauxhall 3l cdti v6
