Results 1 to 10 of 15
Thread: Battery keeps going flat on Signum
    Dec 2010
    Sutton in Ashfield
    Default Battery keeps going flat on Signum
    HI all, I've got a Signum Diesel and for the last year the battery has been a pain in the backside, I've have 2 new batteries all the tests done on the alternator but it's charging fine.
    The battery seems to go flat after 2 days of being stood for no reason at all, there are no lights on when I lock the motor up.
    Any ideas chaps??
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    You have a short somewhere in your electrics which is draining the battery , what else have you had problems with lately as that could give you a clue to what is causing the battery drain
    and still loving it
    Dec 2010
    Sutton in Ashfield
    Quote Originally Posted by bobssignum View Post
    I've been having problems with the screenwash motor.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Have you checked the boot light isnt on or something simple like that?
    Dec 2010
    Sutton in Ashfield
    Quote Originally Posted by s_zigmond View Post
    Yes mate nothing is on when I lock up.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Check the glove box light as well, maybe the switch for it has taken knock and its permanently on.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    As I recall there's a known issue with some versions of one of the models of radios draining power too, I don't remember which though, someone will no doubt have more info than I do to hand.
    Dec 2010
    Sutton in Ashfield
    I'll give that a go when I can get it started. Cheers for the reply.
    Dec 2010
    Sutton in Ashfield
    Quote Originally Posted by Ian-Highlander View Post
    That's the next one I was coming to the radio issue. I'm going to try and disconnect it and see where we go from there.
    Regular Member Grimy's Avatar
    You need to check the current draw on the car with everything turned off and preferably with the car locked.
    You will need an Amp meter with a range of at least 10Amps. If your using a multimeter, check your test leads plugged into the correct socket on the meter if its the older type, and set the meter to 0-10Amp DC. With everything off, disconnect the positive lead from the battery and attach the black test lead to it. Touch the red test lead onto the battery positive terminal and read off the current.
    Any more than 1amp and you have something draining the battery. Remember current= watts / Voltage so a small 5w lamp will pull:-
    I = 5 watts / 12 volts = 0.417 amperes
    Your clock and other random ancillerys will draw a small amout when parked, but you shouldnt have much more than say half an amp.
    A common fault is the rectifier diodes in the alternator failing and becoming a dead short, this then causes the alternator windings to draw current. but it could be anything...
    If pulling fuses out for each circuit to eliminate the fault dosent see a current drop, you need to get the alternator checked out.
  1. battery flat
    By Swedge in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2012, 14:26
  2. flat battery
    By stanlee in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2011, 18:31
  3. Flat Battery!!
    By bigboynigs in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2010, 13:43
  4. Flat battery ****** Signum
    By simsr4 in forum Engine & Drivetrain
    Last Post: 25th November 2010, 09:06
  5. battery going flat
    By kevin in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2006, 12:35
