Results 1 to 10 of 19
Thread: spanner light on..... great
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    Default spanner light on..... great
    I serviced my car at the weekend which consisted of an oil change, check of the pads, oiled the hinges and that was it then today I get the dreaded spanner light over the car. Surely this is just coincidence as I didn't touch anything other than the sump plug, oil filter and engine oil cap.
    It came on first thing then went off after about 10 miles. Then, left work at 5 light was on again for about 2 miles then went off.
    I used to have a diagnostic programme on my other laptop which ran XP but the damn thing gave up the ghost a week ago so bought a new laptop with windows 7 on. Problem is, the diagnostics programme doesn;t run on Win 7!
    Tried the pedal test but nothing happened.........
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by damers2000 View Post
    Check glow plugs if the light shows only when you start the car from cold. Had this before.
    Regular Member M65's Avatar
    Bolton
    Win 7 has an XP compatibilty mode built in depending on which version you use.
    Regular Member djr69uk's Avatar
    Midlands
    Quote Originally Posted by 123rado View Post
    Ditto!
    May 2006
    scotland
    As said, Windows 7, some versions have XP mode. Right click on the program you want to run then if it has run in xp mode, try that.
    Feb 2011
    Selby
    Only the most expensive versions of Windows 7 have the XP mode. Most people have the lower Home Premium version at home.
    However - if you use something like VirtualBox (which is free) you can install XP on a virtual machine running in a window, and use that. It'll connect most USB devices through to the virtual machine.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I would check EGR plug presuming you changed filter you may have disturbed it
    Irmscher Insignia CDTI 130
    May 2006
    scotland
    Quote Originally Posted by rich r View Post
    or VMWARE
    West
    If it's only throwing the spanner during cold starts & going out once the temp has lifted a little, it will be glow plugs... it doesn't usually throw a code either.
    I have just replaced my glow plugs as part of a big service after having the same symptoms.
    Which part of west yorks are you, i'm in Bradford & have an MS509 code reader which is compatable.
    Aug 2010
    Pontefract
    cheers for all the comments, the MD was out today so managed to stick a copy of opcom on one of the old laptops here and got a code, you won't be surprised to know what it is
    P0380 - Glow device general error
    I assume that means a glow plug has failed or is failing?
    I must admit, the starting of the car in a morning varies. SOme mornings it starts more or less straight away and other mornings it takes a few extra turns, would this explain a failed glow plug?
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. Spanner Light and Engine Management Light
    By Paul_NI in forum Engine & Drivetrain
    Last Post: 8th August 2011, 13:42
  5. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
astra engine management light car with virtual spanner
