Results 1 to 10 of 11
Thread: Hids question
    Nov 2009
    Cheshire + East Midlands
    Default Hids question
    Hi folks,
    Bought myself a set of 50w 4300k Hids from hids direct.
    The box came with 2 ballasts and 2 cancellors.
    I have searched the forum and looked at the how-to's but i need to know - do i need to fit the cancellors or will it be ok without?
    My car is a 2003 2.2Dti
    Many thanks
    Woodbridge
    Quote Originally Posted by Ricksh View Post
    Hi folks,
    Many thanks
    Did you ask for vectra C specific ones? If so then I would imagine it will be fine without the cancellors.
    Liverpool
    Just fit em on, makes no difference but I fitted mine to be safe
    Best and easyest way to fit is bumper off and headlight units out!
    Nov 2009
    Many thanks,
    Yeh they are Vec C specific.
    Only reason i ask is the "installation manual" (and i use that term loosely), doesn't even mention the cancellors!
    Regular Member VectraElite 2.2DTi's Avatar
    Sep 2010
    Longfield
    i fitted the cancellers on mine. and as Paul said take the head light units out it makes it so much easier!!
    Full Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    I haven't fitted the cancellers to mine that's because 1 only got sent but try them without and if u need to fit them with, hth
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    I fitted them too, and i just took the airbox out and washer funnel out. Job done. No need to take bumber or headlights off.
    Nov 2009
    Thanks for replies
    I was thinking about taking the bumper off (only because it scares me as i've never done it)
    I have an idea where i'm going to put the ballasts, but where did you put/mount the cancellers?
    May 2007
    Norwich
    Engine : 2.2 z22se
    I put one in the fuse box and I just placed the other inside the wing for now I've got fit a canceller to that side, as above no need to remove bumper just remove washer neck and airbox
    Woodbridge
    Yeah, preface does not need to remove the bumper. As above, one in the fuse/battery box, the other in the wing or where ever you can fit it. To get the air box out, remove the top lid with the screws, remove the sensor (Do not turn your car on with it off) Then pull the bottom part of the airbox out, it is only clipped in, you may have to remove a drain as well. Very easy mate.
  1. Tech 2 HIDs question...
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2012, 09:26
  2. Sorry another HIDS question?
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2009, 01:35
  3. a dumb question about hids.....
    By studmuffin in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2009, 14:35
  4. daft question HIDs\Xenon
    By steveked in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 17:19
  5. hids question
    By beefycol in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2008, 10:07
