Thread: P0621 - Generator Lamp "L" Control Circuit Malfunction
    Dec 2010
    London
    Default P0621 - Generator Lamp "L" Control Circuit Malfunction
    Hi,
    I've got this error code in my Signum 1.9 CDTI 120 for last 3 months. I can clear it but it come back ;(
    There is a yellow spanner on the dash board for first 3-4 minutes of the day (and less than a 1 mile) and then it gone for at least 6h. I can start the car as many times I want and it won't show up again until next day ... or if car is parked for more than 6 hours.
    I have found some posts about faulty or new alternator but in my car nothing has changed and the battery is charged as it should - car starts ever single time without any problems.
    Can any one help? This is very annoying to see this spanner every day in the morning
    Regular Member Tony12's Avatar
    Peterborough
    Engine : 1.9 CDTI
    Mileage : 142000
    Could be a glow plug if its only showing up when its cold
    May 2007
    Norway
    The P0621 comes from the alternator, so that is probably about to fail.....
    Had the same code on mine when it had failed.
    The spanner-symbol can come of a number of issues.....
    Other causes might be:
    - bad glowplug(s) (as Tony12 said)
    - Bad injector (3rd injector-issue)
    - Low Remaining Oil quality (if DPF is installed)
    - Intermittent low charge/battery voltage (your P0621 will cause this to happen)
    Dec 2010
    London
    thanks, will try to the change glow plugs
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    I got this issue too, altnerator is new and 100% tested working as should, 14.2 running volts so know its working and battery spot on,
    Injectiors all tested spot on so won't be that
    Glow plugs- starts straight away so no issues there
    Could this be related to lights?? As it says "lamp" ??? My rear left fog don't come up, been cleaning etc think that area need replacement, could this be the issue?
    Engine : 1.9 CDTi
    Nearside fog wont come on as its not wired/set to come on.
    Regular Member VeCeZ22YH's Avatar
    Jun 2011
    Bratislava
    Engine : petrol 2.2 i 155 PS
    hi.
    generator was reconditioned today and put back into car. i clear the fault :
    (04) - Present
    via op com but after next ignition the batery sing appeared on board again.
    the same fault saved to DTC.
    charging is good in voltage range.
    could anybody help me?
    thanks and please feel free with my english.
    greet from Slovakia
  1. P0650 mil control circuit malfunction code
    By bobsimes in forum Vectra C / Signum Troubleshooting
    Last Post: 5th July 2012, 22:17
  2. P0380 Glow Plug/Heater Circuit "A" Malfunction
    By sinless in forum Vectra C / Signum Troubleshooting
    Last Post: 9th March 2012, 21:38
  3. Fault Code P0621-01 - Generator Lamp....
    By alcutler in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2011, 22:36
  4. mil control circuit malfunction code PO650 ( no dash warning light on car)
    By richiem in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 23:08
  5. What is "MAF or VAF A Circuit Malfunction"?
    By Richard Bignell in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2011, 16:46
Generator Lamp L Control Circuit Malfunction
P0621
p0621 opel astra h
OPEL P0621
opel astra h p0621
https:www.vectra-c.comforumshowthread.php131154-P0621-Generator-Lamp-quot-L-quot-Control-Circuit-Malfunction
p0621 generator lamp l control circuit malfunction
Vauxhall P0621
po621 opel signum
p0621-02opel astra h p0621-01p0621 astra hp0621-01 vectragenerator lamp control circuit malfunctionp0621-03po621 vectrap0621 astragenerator lamp l control circuit malfunction vectra cp0621 vauxhallz19dth p0621generator lampp0621 vectra cp0621-02 generator lamp l control circuit malfunctiongenerator lamp lp0621 - generator lamp l control circuit malfunction
