Thread: Stuck boot lid
    Aug 2010
    Blackwood
    Default Stuck boot lid
    hi guys,
    its driving me crazy.
    any one had the problem with the boot lid not opening?
    pressing the boot button on the keyfob or on the drivers door to unlock, press the button on the boot & all i can hear in the motor but not releasing the boot.
    the lid is shut tight.
    when driving, the display shows the boot is open & the interior light is on.
    any idea what on earth has gone wrong?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Rch its probably the micro switch inside the boot release gone t/u very common fault just had to replace mine two weeks ago
    and still loving it
    Aug 2010
    Blackwood
    cheers for the reply.
    is it an easy job?
    Regular Member Reevo's Avatar
    Nov 2010
    Leicestershire
    As said, its a common fault, loads of posts on it, just do a search. You might be lucky and the switch might just need a clean.
    Engine : 2.0DTi
    Mileage : 73350
    Quote Originally Posted by richje100 View Post
    is it an easy job?
    Fairly easy remove inside trim held by fixing screws and push on spring fasteners, then along the line of your number plate lights you should see a line of nuts holding the above housing in place remove these and you get to the micro switch , as the others have said it may just need a clean , there , is a ball bearing inside the switch which becomes gunged up give that a clean out with wd40 and see if it starts working again if not its a new one required
    I paid £22.60 for one recently from my local stealers the part no of your old one should be 1310 7621 this has been superseeded with a modified version part no 2444 1401
    and still loving it
  1. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  2. boot stuck
    By SausageBoy in forum Bodywork & Interior
    Last Post: 25th April 2008, 00:19
  3. signum boot stuck
    By rosey1 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2008, 16:10
