Results 1 to 10 of 18
Thread: How to source vauxhall connectors? - TPMS
    Apr 2009
    Camberley
    Default How to source vauxhall connectors? - TPMS
    Hi All,
    I work for an electronics component distribution business so getting hold of electronic componenets is no issue for me, however most of the time I would need part numbers.
    I've been thinking of fitting TPMS to my VXR Estate and to do so I would need additional wiring from the Rear Axle plug to the passenger rear wheel arch which would then be terminated with a connector for the reciever to plug into.
    Accessing and soldering in the connectors to the current plug which is in place (the start of the axle loom) should not be to much of problem. TIS shows me which pins need to go where, however I don't know what typre of wire to use and I don't know who the manufacture is of the plug on the other end nor do I know the part number.
    Looking at TIS the plug for the rear receiver looks different to that at the front of my car..
    Here's a pic of the location (all be it for a hatch - It's pretty much the same in the Estate, I've just nicked this image from another thread!)
    The red square is the rear axle loom connector which i'll just populate a further 2 pins with new wire. I'm hoping the pins are there and just empty rather than needed adidtional crimps to populate inside the connector.
    I'll either try and run this wire inside the current loom protector or ziptie a new one next to it to the location of the rear reciever.. I then just need to correct connector to terminate the two wires with..
    I'll then quickly test the loom with a multimeter before plugging it all in..
    So two questions really :-
    1) What type of wire should be used? TIS states GNYE 0.5 (Green & Yellow) and BNWH 0.5 (Brown & White). So the colour is ok, but what is 0.5 about? How many strands would the wire be?
    2) The connector needed on TIS has a code of ZFW 2-142 - How does this relate to an actual part number from a connector manufacture?
    Hopefully the above makes sense and somone can help!
    Regards
    Pete
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    I assume you are in RS or Farnell. Try to grab a catalogue from your counter desk and search for picture, this is faster than using website i reckon.
    Also i have this problem too, try scrap yard or try another plug with same pin count, sometimes they are the same.
    Jul 2010
    Scotland
    And personally i guess most of the plugs by GM are from tyco connectors.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Why don't you buy the new loom and fit it I did on mine
    Irmscher Insignia CDTI 130
    Full Member sulten's Avatar
    Øvre Årdal, Norway
    8 Post(s)
    When I did this I added to wires to the loom, it's difficult to fit the new wires in to the protection hose so i put a new one outside and used plastic cable ties. I have a new complete loom laying here so I will change it at some time.
    The crimps will not be in the housing. I both crimps from Wüerth. If you buy new connectors you will get the housing and a tail of wire with the crimp.
    The 0,5 means the wire is 0,5 square mm and you should use multi strands for high flexibility.
    If you have access to EPC you go to WSM workshop materials and select wiring harness repair kit and look for the what you need ZFW2-142.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Apr 2009
    Camberley
    I don't have a working EPC
    Can anyone get me the part numbers?? Do you have crimp part numbers you used from wurth? Did you do the same mod?
    If so, did you use wurth crimps to go into the X5 connector (Rear Axle connector)?
    Jul 2010
    Saint-Petersburg
    Yes, I know the original part numbers for this item - 13355774 / 1286963 (first GM, second OPEL)
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    easy i have millions of them
    you can either use a front reciever plug and just cut 2 of the locating
    lugs on the plug so it fits in the rear reciever slot or you can use the rear
    abs plugs that go on the hubs,both of these will fit without a doubt
    or you can just order the rear reciever wiring repair kit
    then you can make up the relevant lenght of harness and tie wrap it
    along side to the origional harness
    you will also need the correct female pins for the x5 plug which again the
    wiring repair kit for the x5 plug can also be ordered from dealer but expect
    to pay around £35 per repair kit for these and can be costly.
    Regular Member kantimpalo's Avatar
    Feb 2007
    Spain
    The female pins for the X5 plug can be found in other type of connector?
    10 Post(s)
    Trim : elite
    Year : 2011
    Quote Originally Posted by kantimpalo View Post
    yeah they most certainly can
  1. Any1 know where to source the plugs?
    By yysnet in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 14:32
  2. Where might I source a facelift airbag from?
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2010, 20:13
  3. Recommended source for new alloy?
    By CodeV in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2010, 15:23
  4. Source Another CCR 2006 or Go Aftermarket
    By Hedgehog70 in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2009, 21:38
vectra c tpms x5
vauxhall electrical connectors
vectra tpms
vectra c urec connector add wire
vectra c x5 connector
vectra x5 16 pin plug location
