Thread: Front indicator bulb
    Regular Member Mopar Man's Avatar
    herts
    Default Front indicator bulb
    On a Vectra C I'm ashamed to ask this really.
    My n/s/f indicator bulb needs changing and i cant see how you get to it?
    taunton
    unclip the washer bottle tube where you put the water in. then pull the tube out of the bottle then you can get your hand in to get to the indicator bulb out
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    if you have the facelift model then you will need to drop the bumper
    herts
    sorry it is a face lift.
    taunton
    Quote Originally Posted by matt450 View Post
    this is what the hand book saids to do mate
    Vectra-sport Admin
    Vehicle : VXD
    there are 2 bolts in the wheel arch on the lip of the bumper and liner then a further 2 underneath the bumper on the corner at the front will need to be removed they are torx 20 or 25 , you will also need to remove the 4 nuts along the top of the grill with the bonnet open this should allow you to drop the one side enough to get in and remove the headlight so you can get to the bulb
    hth
    herts
    Quote Originally Posted by Dre View Post
    hth
    This is what i thought. Lot of work for a bulb change.
    Vectra-sport Admin
    Vehicle : VXD
    tbh it sounds harder than what it is i removed a bumper within 10 mins, the vec c bumper is easier to remove than the previous vec b
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2017, 14:42
  2. Facelift Front Indicator Bulb
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2012, 12:28
  3. Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 19:20
  4. indicator bulb
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2009, 18:57
  5. front Indicator bulb
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2009, 18:49
changing indicator bulb signum
vectra c indicator bulb removal
vectra c how to remove indicator bulb
