Results 1 to 3 of 3
Thread: soldering abs wires.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default soldering abs wires.
    right think my problem has been tracked down. started unplugging all connectors on the os/f abs wire. and started to strip back the plastic covering the wire that runs up behind the wheel arch and low and behold i find a broken wire!!! start jumping round like a complete fool with excitement. how does this need to be repaired? i have a soldering iron and all that do i just cut out the little bit near the plug where its broken or cut out a decent size peice and replace it? as i believe it works on resistance so doing a proper soldered joint will be rather important. do i just twist and solder them or is there a better way. dont want to muck this up! many thanks!
    IIRC Vx do a specific repair kit for this.
    Nov 2010
    BRECHIN
    cheers, will see what i can find out. this is what ive got so far. removed the i will call it a link cable! and the we plug on its own is the 1 that is normally attached to the cable that runs under the arch liner just cut the other 1 as well. thought it better to replace both wires.
  1. soldering iron
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 23:57
  2. Soldering iron which is best
    By pipamish in forum General Chat
    Last Post: 7th January 2012, 14:43
  3. Need Help With Soldering PLCC2
    By john506 in forum Electrical & ICE (including SatNav)
    Last Post: 8th September 2011, 20:18
  4. 30w soldering iron
    By luke.oldham in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2010, 21:44
