Results 1 to 10 of 27
Thread: Anyone heard of this ??
    Jan 2010
    west midlands
    Default Anyone heard of this ??
    i have been offered a 2004 plate vectra c tdci for quite cheap as the owner says it needs an engine.
    i have asked him why it needs a new engine and his reply was
    ''its something to do with the inlet manifold , its blowing air around the engine instead of sucking it in''
    has anyone heard of this or anything like it ?
    thanx for any replies
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Sounds like swirl bar has come off and tumbler flaps are leaking
    What engine is it if it's a 1.9cdti 150bhp then this will be the proble
    Any other engine you would need to look into it
    Jan 2010
    west midlands
    is this a fairly easy job and what work would be required to be done ?
    never heard of this before lol
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by lloyd.claire2010 View Post
    Common fault on the CDTI 150's.
    Here is the how2.
    http://www.vectra-c.com/forum/showthread.php?t=121315
    Gazza4
    Jan 2010
    west midlands
    thanx for that !! very useful guide
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    No probs. If you are going to attempt it your self make sure before anything - you obtain the upgraded manifold. To be safe go to the dealer or Autovaux - that's my recommendation anyway.
    Gazza4
    scottish region
    Dec 2010
    Cumbria
    I can tell you the part number off the top of my head! Its 55210201!!
    How do i know these things?????
    (Cause i changed mine last week! Grrrr :-/)
    (£170 on ebay too!)
    Mar 2011
    STOKE-ON-TRENT
    What symptoms led to knowing the issue please.
    I have a Saab 93 with same 150 1.9 engine. I had problem today and rough running, major rattling. sounded terminal to be honest but noticed this swirl bar loose in the engine bay as shown here:
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    The issue may be the EGR valve. The swirl bar fault either gives poor higher rev range performance or lots of smoke low down.
    EGR valve jamming opened when it shouldn't will cause rough running and the odd misfire and high end performance is usually affected. Torque at 1,500-2,000rpm is usually poor too.
    Gazza4
  1. have you heard of this?????
    By iasha in forum Engine & Drivetrain
    Last Post: 23rd November 2009, 16:45
  2. Never Heard or seen..
    By macdad in forum General Chat
    Last Post: 7th June 2009, 19:07
  3. Anyone heard of these
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 27th March 2009, 17:41
  4. Replies: 4
    Last Post: 31st January 2009, 01:54
  5. anyone used/heard about these?
    By carl bear in forum Tuning
    Last Post: 4th July 2005, 22:31
