Results 1 to 3 of 3
Thread: New tyres - clocks out?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default New tyres - clocks out?
    Hi all.
    Finally got 4 new tyres on, unfortunately I've not been able to afford the ones I was aiming for because I've had to spend more on other things so there's 4 new Continentals on it. No more wheel rumble from the back! However, I digress.
    The speedometer is now out - the old tyres were 215/50/R17, these are 225/45/R17. This has caused the clocks to be a bit out at speed. Can this be corrected with Tech 2? Using the sat-nav for speed at the moment.
    Sodding Typical on Sea
    It is quite normal for the clocks to read a few mph different with 225/45's over the 215/50 (economy will also drop a couple of percent too, mind)
    If you can access Tech2 then I suppose yes they can be adjusted but is it worth it if you don't have easy access to Tech2.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Well that's good to know. I'll try and make up a list of all the things I fancy being Tech 2'd on the car then see how much I can get the local VX garage to do it for.
    Cheers.
  1. 140mph Clocks To 170mph Clocks
    By Lean6 in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2012, 20:48
  2. help clocks gone off
    By J100RSA in forum Electrical & ICE (including SatNav)
    Last Post: 9th November 2010, 12:12
  3. clocks
    By dar in forum Bodywork & Interior
    Last Post: 7th December 2009, 22:14
  4. would these clocks fit into my car
    By kdadidog in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2009, 19:24
  5. clocks.
    By mick 1986 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 17:14
