Results 1 to 10 of 16
Thread: Temp guage behaving strange, thermostat probs?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Temp guage behaving strange, thermostat probs?
    Well, ever since the big freeze a while back my temp gauge hasnt been working as it was. Before then, it took a few miles , but it got to about 90, and stayed thereabouts, now it hardly moves, in traffic, it does creep up slowly, but not as much as before, and once I get going it drops right back to zero? that cant be right can it?
    So if this is the stat, how much to replace, or is it an easy job?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    1.8 16v according to your profile? Dead easy and pretty cheap too.
    Thermostat
    You'll need some instant gasket seal too. If your Antifreeze hasnt been changed just as well doing that too, 5lt of Red Antifreeze from your local VX dealer for £15(which is as cheap, if not cheaper than motor factors.
    Z18XE Thermostat Change
    newport
    thats exactly what mine was doing, and thanks to the advise from the good man above ^^, it now works perfectly
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Now not wanting to hand out bad advice the only other things it can be is the Temp Sender unit in the Thermostat Housing unit, you'll more than likely have to go to a VX dealer for this, of course you could spent £50+ on a thermostat from a VX Dealer as they only sell the whole unit including the temp sender unit, mind you for that you do get a new gasket too.
    Whole Thermostat Housing Unit Assembly
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Worth dropping them a line to see if that has comes with the the Temp sender Unit.
    http://www.autovaux.co.uk/LoadPortal...176433&tabid=5
    Oct 2007
    south wales
    So worth changing the whole unit then? probably easier that way?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Its up to yourself tbh. The £7 Thermostat unit takes about 10 seconds to swap over, but the benefits of the complete unit are that you get a new gasket(which is not available separately at the dealers) and, hopefully, a new temp sender unit too.
    Oct 2007
    south wales
    The Autovaux one does include the temp sender unit.
    The stealers quoted me
    "The cost for replacing the thermostat would roughly be £235.44 inclusive of parts, labour and VAT. "
    If its as simple as taking off two hoses, unscrewing two bolts,disconnecting a wire, then I am probably going to do it myself.
    Oct 2007
    south wales
    Just checked again with Autovaux, and the stat for mine is £104!!!! so muxt bea different engine to yours? mine is the VVT version ?
    How come so many people are reporting faulty thermostats?
    Or is it just that people are paying attention to them, having not noticed how poorly they perform!
  1. 2.0 dti temp guage
    By stj in forum Engine & Drivetrain
    Last Post: 26th November 2013, 11:47
  2. temp guage ???
    By mauricemersey in forum Engine & Drivetrain
    Last Post: 23rd December 2012, 13:13
  3. temp guage problem
    By sri-case in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 21:17
  4. Temp Guage - But already replaced :(
    By robert_dale in forum Engine & Drivetrain
    Last Post: 11th May 2010, 17:12
  5. How to fit an oil temp guage on my Signum?
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2009, 12:09
