Thread: 235/40/17 Tyres..
    Liverpool
    Default 235/40/17 Tyres..
    Hi guys
    I have a mitsubishi lying around in my front garden that is on its way out...its got sone 17" wheels on which I think are 8J
    its got 4 pretty much brand new 235/40/17 tyres on it and I was thinking about putting them onto my vectra sri
    can anyone tell me if im going to run into any immediate problems? Rubbing, offset ect..
    cheers!
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    depends if the stud pattern will fit? do you know what pcd they are?
    Full Member Big Sig's Avatar
    I'm sure people have run that size with no problems
    Sodding Typical on Sea
    width will be fine but will cause a fair amount of speedo misreading as the correct ratio would be 215/50 235/45 to have the same rolling radius.Plus a 235/40 onto a 7" rim will pull the sidewall and shoulder in quite a bit, they should really be fitted on a 7.5 or 8J rim.
    Liverpool
    Derek I believe they are an 8j rim the tyre wall is pretty much straight, I told I could even get 245 on if I really wanted but it would be a bit over kill
    Im not sure about the exact stud fitment, all I know is that its 5 stud!! I'll have a go this weekend and see what happens
    cheers guys
    It will have a cast mark on the rear of the rim with the width, my mistake I thought you were going to swap the tyres onto the Vectra rims as I think,,, Mitsi 114.5mm PCD from memory(I think) are a different PCD for the bolts to Vectra at 110mm PCD
    Regular Member stormspiel's Avatar
    Jul 2010
    Wakefield
    I've got 235/45/17's on my 100 edtn rims and they're a good fit. No more bulging than the 215/50's and the rolling radius is within 1%
  3. More tyres....!
2354017 vectra c
