Thread: Automatic Gearbox
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    Default Automatic Gearbox
    Hi guys need some help and advice on my y22dtr auto 2003 sxi.
    I just got this car today its passed its mot so i could finaly drive it after doing the turbo.
    I noticed the gearbox is playing up.
    Ok for first my m8 bought it back from mot and the car was ery hard to move from standing still when i put it into tiptonic i noticed the display said it was in fith gear upon trying to change the gear down it went straight from 5th to 2nd and vise versa when driving.
    I then have been to town and back and when it changes gear the hole car jumps or lunges upon going up and down gear. The car then also displays the picture of a car with spanner light and then restrics the revs (limp mode) then its goes back to normal.
    i have to drive the car very carfully so that it changes gears ok with out hitting 4000 rpm. This only happens when warm/hot when car is stone cold it drives like a dream
    also to note when it plays up when you stop at a traffic light and put it in park then back to D it takes about 4 seconds before it then cluncks into gear and you can drive this is the same in tiptonic
    thanks in advance
    Del.
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    ok update just checked fliud what a pain to get to.
    The colour is dirty but no milky engine is warm ish and the level was mid mark on the bottom set of marks (cold)
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    any one?
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    well did an opcom this evening to see what the car says these are the codes.
    B3601 - Key Capture Relay Circuit Malfunction
    (04) - Present
    B3794 - Switch Cruise Control Circuit Malfunction
    (08) - Not present (explaines why cruse control wont work but what is it stalk?)
    P0100 - Mass Air Flow Sensor Voltage Supply Circuit High Input
    (11) - Present
    P0780 - <Unknown DTC>
    (60) - Not present
    P1704 - <Unknown DTC>
    (60) - Not present
    U2106 - Invalid Data from TCM (Transmission Control Module)
    (71) - Not present
    B3916 - No Communication With Alarm Siren
    (0F) - Not present
    B0283 - Rear Window Heater Low Voltage or Circuit Open
    (06) - Present
    U2103 - No Communication with CAN-Bus (High Speed)
    (00) - Not present
    P0780 - Shift Malfunction
    (60) - Not present
    P1704 - Slippage Of Clutch 'C1' At Neutral Control Off
    (60) - Not present
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Try changing gearbox oil, start simple as it may get expensive!
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    gunna ring a garage to do it tomorrow as never done a gearbox fluid change so dunno were to begin
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    9 Post(s)
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    thanks for links.
    jut not confident doing it as i dont know anything about autos
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Neither did I til I bought a Haynes manual. All explained in detail with pics.
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    i got a haynes manual but the links above show that gotta remove filter pipes turn it over drain torque converter etc.. this i find a bit iffy to do. i am more wanting to do this filter change but dunno how thts not in the manual
  1. Automatic gearbox, recommended?
    By astradriver in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2013, 19:09
  2. Automatic gearbox issues
    By Frederic in forum Engine & Drivetrain
    Last Post: 11th September 2012, 03:31
  3. gearbox automatic info
    By matt180 in forum Engine & Drivetrain
    Last Post: 30th September 2011, 13:47
  4. Signum 2.2 dti automatic gearbox
    By apacheenzo in forum Engine & Drivetrain
    Last Post: 2nd April 2010, 21:06
  5. HELP! Automatic gearbox problems
    By dracunciliasis in forum Engine & Drivetrain
    Last Post: 14th May 2007, 21:48
Vauxhall DTC U2106-00
