Results 1 to 10 of 13
Thread: 3.2 coolant loss and mayo on oil cap
    Dec 2010
    cumbria
    Default 3.2 coolant loss and mayo on oil cap
    the missus 3.2 is using water with no apparent leak had a look today and took oil cap off and there is loads of creamy cack on the cap and down the filler tube,
    the coolant looks ok to me but im no expert maybe slightly dark at the bottom not really sure how it should look.
    so it looks to me that a head gasket might have gone? could it be anything else?
    Thanks!
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    iirc its quite normal for creamy crap on oil cap esp with the 3.2 engines, Not sure about water leak it maybe related but i would check Rad
    Irmscher Insignia CDTI 130
    its normal to have mayo in the cap due to its rubbish design allowing it to sit in the cold air.
    What is the oil on the dip stick like?
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Its probably nothing to worry about, The 3.2s are well known to getting mayo on filler cap and neck due to how the cold air flows over it, Undo the filler cap, Twist off the filler neck, and then replace the filler cap directly onto the rocker cover.
    As for coolant loss...ckeck radiator and coolant pipes. HTH
    Dec 2010
    cumbria
    it seems that the length of the filler neck is what causes it from what i can gather im a bit calmer now lol
    we had a avensis 2.2 d4d before this and the headgasket went on that twice so thats made me jumpy.
    Dec 2010
    cumbria
    thanks for that guys I was in a bit of a panic will take the tube off and see what happens
    the dipstick looks fine. Now I feel like a dipstick now for assuming the worst!
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    If its loosing water with no apparent leak id say its best to get a sniff test done to at least put your mind at ease.
    Oct 2007
    Shropshire
    What is the sniff test?
    Sniff test is a hydrocardon detector that can "smell" any exhaust fumes in the header tank
    Or get your local friendly MOT station to stick their exhaust probe in there as it shouldn't pick up anything.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    20 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 220,240
    My 3.2 loses coolant from the front left (as you look into the engine bay) of the radiator, right at the bottom. In my case, a replacement radiator is the only logical repair. Luckily, mine is only a very slow leak. I am keeping an eye on it until I can afford a radiator.
    Look for a puddle under the front of the car between the centre of the front bumper and the offside corner. If you have one, then your radiator may be on its way out.
    There are ways to check for a head gasket issue, as already mentioned. You can also do a leak down test - part of the "diagnosis" that a main dealer would do. You would need a compression tester, though. The sniff test is also valid, as would be looking for bubbles in the expansion (header) tank whilst the engine is running. Also, oil in the coolant or very dirty coolant can be a tell-tale (not always). Is the engine oil really sludgy?
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
  1. Coolant loss.
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 10th January 2013, 21:18
  2. Coolant loss 3.2 V6...
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 11:31
  3. Gsi coolant loss
    Last Post: 20th February 2010, 15:13
  4. coolant loss
    By lilangel in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 12:05
  5. Coolant Loss
    By george in forum Engine & Drivetrain
    Last Post: 12th April 2007, 06:39
water leak from 3.2 gsi
signum mayo in the oil filler cap
https:www.vectra-c.comforumshowthread.php131046-3-2-coolant-loss-and-mayo-on-oil-cap
