Thread: Removing signum gear knob
    Wakefield
    Default Removing signum gear knob
    I need to replace the gear knob, are they bonded on? or is it just screwed on very tight
    thanks
    Regular Member Harry's Avatar
    Uxbridge, London
    from what i know rich, it's a case of getting a hacksaw to the existing one and replacing it with new.
    afraid that's the only way to do it- best left alone......i think so!!!
    Regular Member 2ltrT's Avatar
    North-East (Middlesbrough)
    IIRC, remove the trim from around gator.... release gator from console, and pull up over the gear knob.
    under the gator you will see a black collar with a spring.. just above the spring there is two clips, press them in and the knob will pop off. ...
    i'm not sure about replacing the knob with an aftermarket one tho, as when the knob is removed it also comes out with part of the selector assy.
    replacing like for like shouldn't be a problem.
    Wakefield
    the leather on the gear knob has come unstuck, i may just have to restick it, but i could end up making a mess of it. i rang a dealer who thinks they are bonded on and therfore requires a whole new lever, £100.
  1. Signum Gear Knob fix?
    By Signumtommy in forum Bodywork & Interior
    Last Post: 7th April 2011, 20:00
  2. Self-removing gear knob
    By Ollie in forum Bodywork & Interior
    Last Post: 16th September 2010, 15:52
  3. removing gear stick knob
    By bpv29 in forum Styling
    Last Post: 28th May 2009, 22:45
  4. Removing gear knob ???
    By MAF 3.2 V6 GSi in forum Bodywork & Interior
    Last Post: 5th April 2009, 13:33
vectra c gear knob removal
how to remove vectra c gear knob
how to remove vauxhall vectra gear knobhttps:www.vectra-c.comforumshowthread.php13104-Removing-signum-gear-knobvectra c remove gear knobremove gear knob vectra chow to change vectra c gear knobhow to change a vectra gear knobvauxhall vectra gear knob removalremove gear knob vauxhall vectra cremoving vectra c gear knobvectra c gear knobvectra c gear knob removehow to change gear knob on vauxhall vectra chow do you remove a Vauxhall Vectra gear knobhow do you take off the gear knob on a vauxhall signum how to remove gear gaiter vectra chow to change the gear knob on a vauxhall vectravauxhall signum gear knobvectra gear knob changeremoving a opel vectra automatic gear knobvectra c gearnob removal 2004how to remove gear knob on a 2004 vauxhall vectrahow replace opel vectra c 2004 gear stick how to remove gear knob on a vectra c
