Thread: Fault codes c0040-06 and u2142-00
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default Fault codes c0040-06 and u2142-00
    hi all, many thanks to tappetpaul for reading my codes at the weekend there. Think this is in the right section, sorry if not.
    done some reserch into them "c0040-06 circuit open or low voltage" is going to be the front right abs sensor. going to strip the plugs down and check again for corrosion. but am wondering where the wire disapears up behind the arch liner are there anymore plugs up to the abs pump? or is it just 1 solid cable? do they have a habit of breaking? or is it going to be just a new abs hub bearing to solve the problem?
    and when it come to "u2142-00 no communication with YRS" its a yaw sensor thing. to be honest ive not a clue what it is or where it is. he did clear the codes and this one went away but the 0040 came back right away.
    any advice on this cheers, Tim
    Nov 2010
    BRECHIN
    anyone?? before i start pulling of my arch liner for no reason??????
    chesterfield
    Had same problem on my last vectra.
    Turned out to be the link wire.
    You can see and test easily.
    If you look in the arch you Will see a black wire which goes to hub and other end
    Disappears through arch to engine bay.
    On mine this wire could be disconnected from two points within the arch area.
    Two white plugs.
    Took me 2 min max to disconnect and remove while car was on full lock and still on the ground.
    I tested the wire with a test meter and found it had a broken core.
    Think it cost me 12 pound for new wire.
    Nov 2010
    BRECHIN
    cheers, found a broken wire on the loom last night repaired it but still no joy. will take out the link wire today and test it. my link wire is slightly different but wont do any harm in testing it. cheers
  1. fault codes
    By Swedge in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2012, 19:10
  2. help with fault codes
    By bobsimes in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2011, 06:42
  3. Fault codes, what am I looking for?
    By bones341 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2011, 13:10
  4. fault codes!!!!!!!!!!!!
    By wullierob81 in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2010, 20:27
Vauxhall C0040
Vauxhall DTC C0040-06
vauxhall dtc c0040-26
GM DTC U2142-00
Opel DTC C0040-06
Saab DTC U2142-00
https:www.vectra-c.comforumshowthread.php131026-Fault-codes-c0040-06-and-u2142-00
u2142 code
Opel DTC U2142-00
opel u2142
u2142-00
Opel DTC C0040-00
u2142 code vectra c
Vauxhall U2142
vauxhall insignia fault code c004006
zafira c0040
c0040 fault code signum
u2142 fault code
c0040 fault code
Saab DTC C0040-06
u2142 opel vectra c
c0040-06 opel signumsaab code c0040c004006vectra c kod C0040-06
