Thread: Spanner/oil can light
    Regular Member fuzzbomUK's Avatar
    Milton Keynes
    Default Spanner/oil can light
    Hi all, does the spanner over an oil can just mean needs an oil service?
    It looks almost the same as the oil can and spanner but without the 1000 underneath it.
    Oil is at the top of the notches on the dipstick so level is ok.
    on a 53 plate 1.8 sxi if that makes any difference.
    many thanks.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Think that one means that there's a fault code stored in the ECU?
    Regular Member sebadee's Avatar
    macclesfield
    if you press and hold milage reset button it will say how long till next service is due
    Quote Originally Posted by tony-1977 View Post
    No, thats the spanner over the car
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Oops I stand corrected
    Milton Keynes
    I have a 3.2 so i am used to the usual servuice lights etc but never seen that one before.
    Picking the car up tonight as just bought it for my mum will check the sevice interval then.
    I also have an OP-COM so might plug it in and see if there is any codes if the service interval is ok.
    thanks again.
    Quote Originally Posted by fuzzbomUK View Post
    This only appears when you reach the service limit
    On EcoFlex you can make a small version appear with the miles to next service underneath
    Once you are under 500 miles the larger version appears every time you insert or remove the ignition key
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as M8 says
    Milton Keynes
    Yeah you guys are right. done manual reset and now no warning. many thanks.
    only bummer is the thermostat looks dodgy. temp needle hardly moved while driving. went up when stationary.
    checked on ebay £30 grr.. why the hell do you need to buy a housing as well as the stat on vectra's lol. my 3.2 was £50 when i had to replace that.
    Oh well. thanks again.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
