Thread: full canbus help please
    chesterfield
    Default full canbus help please
    Hi. I have scanned through loads of posts with similar situations
    but still not found what im looking for.
    Can anyone help please.
    I have a vectra c 06 face lift 1.9cdti 150 and believe its full canbus?
    I am putting this car on the road as a taxi and require
    a permanent live feed to the taxi meter machine
    i see some people say the car power system shuts down after
    20minutes.
    I need it to be totally permanent due to times when work is slow and could be an hour between jobs etc.
    Has anyone come across a permanent live yet that could do this job?
    I keep hearing boot fuse board mentioned.
    I don't fancy running new feed from battery as can imagine been a pain getting through the bulkhead.
    Or is there a point on main fuse board that the battery live comes too before it goes through canbus system?
    Any help appreciated
    thanks in advance people.
    chesterfield
    Anyone?
    Jul 2009
    The Rift, Cardiff
    I'd say your best bet will be to run a direct feed from the batt. There's a gromet on the passengers side under the scuttle tray to the right of the pollen filter (lookin from the front). You can access it from the inside by removing the glove box (5 screws & unplug light). Put an inline fuse as close to the batt as possible and if the meter doesn't have a proper power switch, as opposed to a stand by switch, then i'd also fit a switch to prevent overnight drain.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by ChrisBilly View Post
    Administrator plasma's Avatar
    On the Forum
    404 Post(s)
    Engine : 150
    Mileage : 74000
    Someone elses taxi's I know has the meter feed direct from the battery. Is quite easy to do. glovebox out and through the grommet behind it
    chesterfield
    Thanks to all who replied.
    Will take it from battery then now i know there is a route through
    . The meter has on and off switch anyway so straight feed from battery
    with in line fuse.
    Thanks all
  1. half canbus to full canbus
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2017, 22:42
  2. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  3. For Sale: Full Canbus GID
    By MURDO in forum Parts for sale
    Last Post: 21st May 2012, 13:30
  4. full canbus can i do it???
    By damadom in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2009, 13:28
  5. Half CANbus/Full CANbus?
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2006, 20:13
