Thread: Resetting service light cdti sri 120 05
    Regular Member hamish123's Avatar
    norfolk
    Default Resetting service light cdti sri 120 05
    Hi i serviced the vec yesterday and presume you can reset the service indicator or is it a job you have to get the Garage to do .
    The car is an 05 cdti sri 120
    Full Member Big Sig's Avatar
    You can do it yourself, have a search as its on here somewhere!
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Have a look through a few of these Hamish
    http://www.google.co.uk/search?hl=&q...GB400&ie=UTF-8
    Hopefully it'll point you in the right direction
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Get in driver's seat.... key in ignition..... press and hold trip reset button.... press and hold brake pedal...... turn ignition to all lights on but not start.... trip display flashes a few times then resets.... once it stops you can release brake and trip button. Switch off ignition. Get out of car. Lock car. Go have cup of tea (other hot and cold beverages are available). Be smug you have not paid a garage to do something you can do yourself.
  1. what does resetting the ecu do
    By justin32 in forum Engine & Drivetrain
    Last Post: 6th January 2013, 23:12
  2. Abs resetting
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2012, 12:05
  3. Resetting Service Light.
    By Vectra-Dog in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 21:34
  4. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  5. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
vauxhall vectra 1.9 cdti service light reset
