Thread: Another towing question
    Feb 2011
    n wales
    Default Another towing question
    Hello all. Im just about to wire in my12 s socket and im not sure exactly what goes where. In the car i had a relay with a wire that connects to the trailer wiring socket (red), a wire that plugs into fuse 28(red) they plug into a relay and then the relay has a earth and a yellow wire. I have got this diagram but unsure which wire goes where. Any help would be greatly appreciated
    Oct 2010
    Lincoln
    If you are using a 'proper' relay then the wiring should be marked on the relay itself. I've got one which I'm not using so will dig out the wiring 2moz for you.
    Feb 2011
    n wales
    Quote Originally Posted by lencuff View Post
    Thanks. I think its the proper relay as it connects to the towbar plug that plugs into the rec. The previous owner cut the wiring so i havent a clue where it goes. I think one is permenant live and the other is live when the cars on. Thanks
    Oct 2010
    Lincoln
    If it plugs into the REC then I had the same problem, previous owner removed towbar and simply chopped the cables (after removing F25). I found that luckily the supplied Vx cabling is the same colours as the standard 12S/12N wiring so I got some inline crimp connectors and connected them back colour for colour. Make sense?
    Feb 2011
    n wales
    Sort of. Its the 12s wiring so i am using a twin electrics not a genuine one. (the sockets bolted to towbar) Thanks
  1. 1.9cdti 150 and towing question
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2009, 18:59
  2. Vehicle Towing question
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2008, 13:32
  3. towing a car
    By steve.s in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2007, 18:39
  4. Towing Question
    By AJA in forum General Chat
    Last Post: 15th June 2007, 20:10
  5. towing with 2.2 dti
    By daveg8843 in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2006, 10:07
