Results 1 to 3 of 3
Thread: o2 sensor fuse keeps blowing
    norwich
    Default o2 sensor fuse keeps blowing
    my 02 sensor fuse keeps blowing the fuse blows when i go over speed bumps or turn corners sharply
    Regular Member LADmachining's Avatar
    Hampshire
    Sounds like the wiring loom is moving and chafing on bracket or part of the bodywork, which is then causing a short circuit.
    You will have to follow the loom from the o2 sensor back to the fusebox and visually inspect all wiring to find the problem.
    norwich
    many thanks ill have a look in to that 2morrow
  1. cigarette lighter blowing a fuse
    By ciderman in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2012, 22:42
  2. Heated seat blowing fuse
    By karlmax27 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2011, 14:21
  3. Problem with amplifier blowing fuse
    By masj78 in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2011, 22:27
  4. My amp fuse keeps blowing?
    By sirnapper in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2009, 20:41
  5. Headlight washer system fuse keeps blowing
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 19:58
vauxhall signum heated o2 sensor fuse
o2 sensor fuse vauxhall
