Results 1 to 10 of 24
Thread: water pump failed think timing may have sliped help plz!!
    Jun 2009
    scotland
    Default water pump failed think timing may have sliped help plz!!
    hi all i have vec 2008 1.9cdti the water pump failed and riped part off th timing belt but most off it was still on tho not totaly snapped .
    I have now put new timing belt kit on and it wont start i think i have timing correct did look for a how 2 on this but could not find them and i was told the pump was not a timed one any help on this would be great
    Regular Member Mopar Man's Avatar
    herts
    Was the timming marks aligned when ypu removed the belt?
    Does the compresion sound ok when cranking?
    Regular Member LADmachining's Avatar
    Hampshire
    Check for any broken rockers. These are sacrificial, and break rather than bending valves.
    Depending on engine speed at the time of failure, there could still be damage to valves and pistons.
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    Was the car not under warrenty still being 08?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Si-SRI View Post
    As long as it has done less than 60k
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Jun 2009
    scotland
    thanks for the replys guys i just had a look at the thread there this maybe silly i was told to do the timing different than the way in that thread i was told to take out a screw in the cam cover and turn the cam round till a locking pin or bolt slots into a hole in the cam locking it in the correct cam timing starting to think the timing might still be out but when am turning the engine over by han there is no bangs or just turns nice and freely
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    this is the correct way as you stated, but when you have the cam locking pin in place you also have to check the crank, i presume your using the 'sealy' locking kit, pic of crank locker.
    Jun 2009
    scotland
    hi there i dont have the full locking kit just the cam pin and thats all there is a white notch on the crank pully am i rite in saying u would rite in saying u would line this white mark up with the mark on the crank caseing or cover thing at bottom of the engine ?
    Jun 2009
    scotland
    just took the cam cover off all the rockers are bust need complete set of them now all i need to do is gett the timing spot on i have looked for threads on how to do this but not sure of it can any one help plz i have to do the timing from scratch as the timmimg was lost when belt sliped
  1. timing belt and water pump
    By MARTIN FROM LLAN in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2012, 20:33
  2. Timing Belt Due - Water Pump Too?
    By M65 in forum Engine & Drivetrain
    Last Post: 27th June 2012, 15:37
  3. For Sale: 3.2 v6 Conti Timing Kit + Water Pump
    By Turion in forum Parts for sale
    Last Post: 4th January 2012, 21:59
  4. Timing belt and water pump done
    By DavieVectd120 in forum Engine & Drivetrain
    Last Post: 1st April 2010, 19:03
  5. timing belt and water pump
    By mhvcbv in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 13:09
vauxhall vectra timing belt snapped
water pump and timing belt snapped and car was really rattling
