Thread: turbocharger chattering/blowing/hissing? advice
    Nov 2010
    inverness
    Default turbocharger chattering/blowing/hissing? advice
    recently upgraded from a z20net turbo to the td04 b207r turbo, after 200miles of so the turbo is chattering/blowing/hissing noise when reving or driving.
    not sure if its maybe the gasket has gone or maybe manifold has cracked. hmm or the actual turbo is goosked.
    Regular Member LADmachining's Avatar
    Hampshire
    Perhaps the intercooler has developed a leak?
    Unlikely the turbo has failed after such a short time unless it has been starved of oil.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i would be checking the boost/intercooler pipes for leaks.. start with the short angles reducer pipe on the bacl of the engine, this goes fromthe compressor housing to a boost pipe, they are know to give way near the joins... the way to check/work on it is from underneath the car, if the car is not cold be very careful as the downpipe is very close and you will burn your hands
    Nov 2010
    inverness
    thanks . will have a look at that. do u recon if its just a boost leak the turbo will be ok
    Jun 2009
    South Coast
    sounds like a boost leak to me, just like one I had. I will be replacing that pipe and the others with silicone jobs very soon as when i checked them on friday afternoon they are swollen and mishapen and that back one seems to have deteriorated again
    Nov 2010
    inverness
    hmm yes i see what your meaning, i will have a look at that as it was slightly blowin where you said. only problem the rattlin noise sounds like its the turbocharger or the turbocharger bearings or something.
    Jun 2009
    South Coast
    hmm not sure about that rattling though, i have not blown a turbo yet to advise on that..
    are you sure its not something thats loose, i take it you have transplanted an entire B207R unit, do yoju knwo the history of the engine? did you fit it yourself etc?
    Nov 2010
    inverness
    its basically a z20net and put a td04 b207r turbo in it which is a straight fit apart from the oil and water lines that where changed. got a mate to do it well he claimed he knew what he was doing
    Jun 2009
    South Coast
    oh right you just changed the turbo... am very familiar with doing that kind of thing on a z20net.. the boost is much higher for the hoses and they can be blown off, defo check all hose joins..
    WGAF#5
    yup as Nige said pipes are the fisrt thing to check ..... when i transplanted the B207R onto my 2.0 the intercooler pipe kept getting blown off
  1. Turbocharger
    By viper8 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 17:16
  2. sat nav chattering
    By tyler boy in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2011, 21:26
  3. chattering
    By alijlacy in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 19:38
  4. 1.9 CDTi 150 (Z19 DTH) New Turbocharger
    By Maverick in forum Parts for sale
    Last Post: 9th March 2010, 19:41
  5. Where's the turbocharger....
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2010, 18:28
