Results 1 to 10 of 13
Thread: Any body in north wales chester area with tech 2 or opcom.
    Feb 2011
    n wales
    Default Any body in north wales chester area with tech 2 or opcom.
    Hello just wondering if there is anybody in the north wales/ chester area with tech 2 or equivalent who is able to activate my trailer module on my 1.9 cdti. Thanks
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    9 Post(s)
    The trailer module is plug and play afaik.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Feb 2011
    n wales
    [QUOTE=sulten;1462097]The trailer module is plug and play afaik.[/QUOTE
    Thanks for reply. I have installed everything but i need to activate it in REC DIS And IPC. I have done the REC but cant do the others as my opcom is playing up. Paul
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    [QUOTE=paulcdti150;1462131]
    Quote Originally Posted by sulten View Post
    Have you try to connect trailer to the contact and see if its light? Last time a mounted I didnt need to activate with tech 2.
    Feb 2011
    n wales
    [QUOTE=zafira;1462188]
    Quote Originally Posted by paulcdti150 View Post
    I have and it works ok but the light is on on the dash to tell me the bulb has failed.
    Øvre Årdal, Norway
    9 Post(s)
    If the lights is ok but you got the warning it's probably because the trailer have used common wire for right and left light.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Feb 2011
    n wales
    Rigtht i will look into this . Thanks
    Oct 2010
    Lincoln
    If you are taking the trailer wiring from the rear light cluster(s) then did you use a 7 way bypass relay? If not then this will cause the problem you have. Mine is wired directly from the REC and I have OPCOMM'd everything in except the IPC as there doesn't seem to anything there to set to present?
    Having said that, it all works fine even to the point that when a brake light failed, the sidelight took over
    Too far away to help with OPCOMM.
    Feb 2011
    n wales
    Quote Originally Posted by lencuff View Post
    Hello thanks for reply. I have bought a genuine trailer module and installed that and the wiring. The problem im having is activating the trailer module in the DIS as my opcom wont recognise. The lights work but the bulb faliure comes on on the main instrument cluster.
    Regular Member Kev_G's Avatar
    Jul 2009
    C:\Uk\Chester_North West
    Contact Nige at the below and say Kev sent you.
    M E & J W Pumford
    2 Alderley Rd
    Hoy Lake
    Hoylake
    Wirral
    Merseyside
    CH47 2BG
    Tel: 0151 632 0002
    Maybe a small fee but he has tech 2 and knows his stuff. He is admin on MIGWEB with me
  1. Anyone around N wales and chester area :)
    By vxr_and in forum Introduce yourself.
    Last Post: 26th December 2012, 18:46
  2. someone with opcom near me??? South Wales
    By webber446 in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2011, 00:00
  3. Anyone with Tech 2 in the East/North/West London/Essex area...
    By silestanix in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2011, 23:39
  4. Op-Com/Tech 2 Ashington area (north east)
    By steve in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2010, 18:01
  5. Re-mapper north west/north wales
    By puchos in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2007, 09:28
