Thread: need bit of help
    Feb 2011
    dorset
    Default need bit of help
    Hi guys new to this site just picked up my 04 signum 2.2 cdti today.
    On the way back i over took a van and she just shuddered and cut out and turns over but will not start so had to be towed back any one got any idears at all.
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Er you have a2.2 dti mate not Cdti did it go in to limp mode if so coil be a split boost pipe
    Feb 2011
    dorset
    No she just juddered and cut out, forgot to say that when I picked her its was almost out of fuel. she had 33 miles left n roughly cut out at 30ish
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    dont trust the range reading where is needle on dash
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    If you have run out of fuel you will have to bleed the system on the Dti before it will start,you should never get that low on fuel,pulls all the crap through from the tank,runs the high pressure pump without lube,pain to bleed.you may have to change fuel filter.
    Feb 2011
    dorset
    can any one link how to bleed the system
    Feb 2011
    dorset
    Hi again guys had a fault code reader pluged in and it said cam shaft sensor has gone any one help out by posting a pic or can anyone tell me where it is thxs.
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    2.2 dti's don't have a camshaft sensor. It'll be the crankshaft sensor. The electrical connectors may just need a clean up. Mine ground to a halt at Calais port & it turned out to be this. The sensor is at the bottom of the engine on the left (looking from the front to the rear).
