Likes Likes:  1
Results 1 to 2 of 2
Thread: Info: Torque guide values Z19DTH
    jilava
    Default Info: Torque guide values Z19DTH
    Engine Z 19 DTH
    Nm
    Exhaust manifold to cylinder head
    251)
    Front exhaust pipe to exhaust manifold
    201)
    Heat shield, exhaust manifold
    9
    Axle shaft
    Release 150 Nm then 250 Nm1) 2)3)
    Exhaust gas recirculation valve to intake manifold
    25
    Drive disk
    160
    Battery to battery support
    10
    Battery casing to body
    15
    Battery terminal + and -
    4
    Oil filter housing cover to oil filter housing
    30
    Crankshaft rear seal ring
    9
    Rear reaction member to transmission
    80
    Rear reaction member to rear reaction member bracket
    80
    Rear reaction member to front axle body
    60
    Front reaction member to transmission
    80
    Front reaction member to front axle body
    60
    Torsional vibration damper to crankshaft adapter
    25
    Throttle valve module to intake manifold
    9
    Thrust plate to flywheel (M7)
    151)
    Thrust plate to flywheel (M8)
    281)
    Pressure regulating valve to pressure reservoir
    60
    Intake manifold to cylinder head
    251)
    Transverse link guide joint to steering knuckle
    30 Nm + 60° + 15°1)
    Accelerator pedal to bulkhead
    9
    Alternator to alternator bracket
    60
    Transmission to oil pan
    40
    Transmission to cylinder block
    60
    Transmission bracket, left
    55
    Sheathed glow plugs
    10
    Support, drive shaft to oil pan
    50
    Compressor support to engine
    50
    Bracket, swirl valve adjustment to block
    9
    Alternator bracket to bracket
    60
    Alternator bracket to engine block
    25
    Bracket, injector in cylinder head
    25
    Bracket, catalytic converter, M8
    25
    Bracket, engine control unit M8
    20
    Heat shield to exhaust manifold
    9
    High pressure pump bracket to engine block/cylinder head
    25
    High pressure pump, drive gear
    501)
    Crankshaft pulse pick-up to cylinder block
    9
    Catalytic converter to turbocharger (M10)
    64
    Refrigerant line to compressor
    20
    Refrigerant line to condenser
    10
    Ribbed V-belt tensioner
    50
    Upper/lower ribbed V-belt guide roller (only air conditioning)
    50
    High pressure fuel line (M12 x 1.5)
    25
    High pressure fuel line (M14 x 1.5)
    23
    High pressure fuel pump to support
    25
    Fuel rail
    25
    Cooler, exhaust gas recirculation to cylinder head
    25
    Lower cooler bracket
    15
    Coolant pump to cylinder head
    25
    Coolant temperature sensor to thermostat housing
    20
    Coolant distribution pipe to thermostat
    9
    Coolant distribution pipe to cylinder head
    9
    Crankshaft bearing cap on cylinder block
    25 Nm + 100°
    Intercooler to radiator
    4
    Intermediate shaft bearing block
    55
    Metal pipe, exhaust gas recirculation
    25
    Left engine damping block to adapter, left engine damping block
    55
    Left engine damping block to body side member (M8)
    20
    Right engine damping block to body
    55
    Right engine damping block to right engine bracket
    55
    Engine vent pipe to camshaft housing
    9
    Engine bracket, timing side (M8)
    25
    Engine bracket, timing side (M10)
    50
    Engine oil filler port to camshaft housing
    9
    Nut, steering intermediate shaft
    22
    Camshaft drive gear
    1201)
    Camshaft sensor to camshaft housing
    7
    Camshaft support to cylinder head
    25
    Oil drain bolt in oil pan
    20
    oil separator housing to bracket
    9
    Oil pressure switch
    22
    Oil filter housing/heat exchanger housing to cylinder block
    50
    Upper/lower oil dipstick guide tube
    9
    Oil pump to engine block
    9
    Oil return pipe to engine block
    25
    Oil return pipe to turbocharger
    9
    Oil intake pipe to oil pump / engine block
    9
    Oil baffle plate
    9
    Oil supply line, turbocharger to cylinder block (M12)
    15
    Oil supply line, turbocharger to turbocharger (M10)
    15
    Oil pan M6
    9
    Oil pan M8
    25
    Swing arm to spring strut
    651)
    Con-rod bearing cap
    25 Nm + 60°1)
    Wheel to wheel hub
    110
    Tube, vacuum pressure to cylinder head
    9
    Bolt, toothed belt drive gear (left hand thread)
    3401)
    Flywheel to crankshaft
    1601)
    Sensor, dynamic oil level check in oil pan
    9
    Charge pressure sensor to intake manifold
    9
    Rail pressure sensor to pressure reservoir
    70
    Tie rod to steering knuckle
    351)
    Starter to cylinder block
    25
    Spur gear exhaust/intake camshaft
    1201)
    Thermostat housing to cylinder head
    25
    Vacuum pump to camshaft housing
    20
    Compressor to compressor support
    25
    Condenser to intercooler
    4
    Sealing plug in camshaft housing
    16
    Reinforcement plate to body M10
    55 Nm + 45° +15°1)
    Reinforcement plate to body M12
    90 Nm +45°+15°1)
    Rear of front axle body to body
    100 Nm + 90° + 15°1)
    Front of front axle body to body
    80 Nm + 120 ° + 15 °1)
    Converter to drive disk
    30
    Toothed belt cover M6
    9
    Toothed belt cover M8
    25
    Toothed belt tension roller
    30
    Toothed belt guide roller
    50
    Intermediate shaft at bearing plate
    18
    Cylinder head to engine block
    65 Nm + 90° + 90° + 90°1)
    1) Use new fastening nuts, bolts
    2) Tighten nut to 150 Nm, release nut 45° and tighten to 250 Nm
    3) Fitting and removal of fixing bolts or nuts with impact drivers is not permitted
    HTH someone.
  2. Likes Lao liked this post
  3. #2
    Regular Member Mopar Man's Avatar
    herts
    Thanks andreitone
  1. z19dth fuel filter housing torque setting?
    By justin32 in forum Engine & Drivetrain
    Last Post: 27th December 2011, 11:31
  2. emissions values for 2.2 Direct
    By DaveG in forum Engine & Drivetrain
    Last Post: 3rd April 2010, 15:07
  3. Used Car Values - Good News!!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2009, 17:19
  4. Found this info. Torqe Values Vectra C Y20DTH , Y22DTR
    By andymagee1982 in forum Engine & Drivetrain
    Last Post: 20th October 2008, 01:18
  5. Oil Change / Torque values for 3.2 engine
    By D18 in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2008, 15:40
z19dth torque settings
vectra cdti oil filter torque
z19dth head bolt torque
vauxhall zafira flywheel bolt torque
vectra c 1.9 cdti 8v vacuum pump torque setting
flywheel bolt torque vauxhall
what is tighting torque for camshaft box on 2014 2.0 vauxhall insignia
1.9 cdti injector torque settingvauxhall vectra 1.9 cdti diesel pump torque specsvectra 1.9 cdti exhaust manifold torque settingshead bolt z19dthinsignia mains tightening torque A20DTHtorque settings for glow plugs on a vauxhall vectra cvauxhall zafira 1.9 cdti flywheel bolt torque settings cam cover z19dth bolt sizez19dth egr boltsz19dth cam cover bolt sequencevectra c 1.9 cam carrierz19dth high presure fuel pump nut sizez19dth head rock torquetorque setting for oil filter housing vauxhall insigniaz19dt camshaft torquetorque flywheel 1.9 cdtiflywheel bolt torque vectra 1.9 cdtivectra cdti injector torque
