Thread: Biodiesel
    Preston Area
    Default Biodiesel
    So what do we know about his? is it any good? does it work? do we need to convert anything? where do you get it!
    Discuss?
    from what i've read it's not really reccomended for CDTI style high pressure diesel engines..
    DTI engines with a old style pump could run on it thou..
    Regular Member Stewie's Avatar
    Suffolk
    One of the Taxi firms we look after put this in one of their new Transits. It didn't get far before it had to be towed in!
    Preston Area
    fair do.. sod that idea then !
    Belfast
    The problem is, there's lots of different types of biodiesel. Some are more compatible than others.
    Pure bio is the one you need to avoid if you're not sure - it's just de-esterified cooking oil.
    A bio blend is the stuff you should be fit to run no problems. I run a 95% bio blend, but add a little real diesel to the mix so it works out between 70-80% bio to 20-30% DERV.
  1. Biodiesel
    By mon in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 17:21
  2. Biodiesel
    By woodaj in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2009, 18:34
  3. Biodiesel on a 2.0DTi??
    By redraptor_141 in forum Diesel Engine related
    Last Post: 14th March 2009, 23:59
  4. This is what happens to biodiesel in winter!
    By bygumlad in forum Diesel Engine related
    Last Post: 15th January 2009, 20:36
  5. B30 Biodiesel
    By spiroman in forum Diesel Engine related
    Last Post: 15th January 2009, 17:18
