Results 1 to 2 of 2
Thread: p1481,p1482,p1483.
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    Question p1481,p1482,p1483.
    As per Taffybhoy's thread in chat, I have had intermittant spanner light for months, and it now seems to be getting worse.
    At first I had numerous codes relating to thermostat and misfires but I have slowly got rid of most of them.
    But still the spanner light! Only codes left are:
    p1481
    p1482
    and p1565 which is cruise control servo related; don't think this one is causing spanner as rarely use CC. If anyone knows about this code tho please explain.
    I know these codes relate to the radiator fan. I have checked and cleaned the fan ECM, also the two main ECU connectors. My car (z18xe) does not seem to have the silver box connector on the battery box that the diesels have (i read about this and saw pictures in an old thread)
    What I want to know is there anything else like wiring or connectors I can check? I am reluctant to replace the fan ECM until I rule everything else out, but spanner light is doing my head in.
    May 2014
    Denmark, north jutland
    Vehicle : Vectra C GTS
    Trim : GTS
    Engine : Z18xe
    Hi
    i have same error codes. Do you think it might be the temperature sensor that is out of range? I have tested all 3stages vy opcom and they all works well.
    br, lars
  1. P1481 fault code
    By stevedee3 in forum Engine & Drivetrain
    Last Post: 13th January 2016, 23:09
  2. Code P1481-P1482-P1483
    By Aikon58 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2013, 12:30
  3. Fault Code P1483
    By chas901 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th December 2012, 17:41
  4. Error CODE P1482
    By Bikedylan in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2011, 11:16
  5. Fault code P1482
    By tridley in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2011, 17:39
p1483
p1481 opel vectra
p1483 opel vectra c
z18xe p1483
p1482 vauxhall vectra
p1481 opel
p1481 vauxhall
