Thread: Problem with my vectra? Help pls
    Feb 2011
    Stoke-on-Trent
    confused Problem with my vectra? Help pls
    Hi i'm a newbey on here, i have a vectra 1.9cdti and think my alternator is not working. I have read a few posts about other alternator problems. Mine is losing battery power as all electrical things stop working including power steering etc and get the disco lights on dash. The only thing thats strange is my battery light doesn't stay on it goes out. Had new battery and its the same, only works after a good charge. I am wondering how hard is it to remove it as it looks difficult ? And where do you start ? Seen one thread about removing the air box ? Help Please ! youngen
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Second time i have posted this link today
    Hope it helps you m8
    http://www.vectra-c.com/forum/showthread.php?t=92987
    and still loving it
    Aug 2009
    sheffield
    you have done the battery / alternator tests ?
    Feb 2011
    Stoke-on-Trent
    Hi thanks for the advice, i have replaced the battery and that one lasted a few days and was drained again. Have tested using a volt meter and shows nothing when engine is running. The big thing is the light not staying on when car is running ??? I know it should stay on if its not charging ?? Dont want start removing it if its not that HELP PLEASE.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Was there a VX recall on alternators? might be worth checking at the dealers
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Quote Originally Posted by youngenmic View Post
    Yep loads of threads about this. Basically sometimes the light doesn't come on even when the alternator is goosed, so don't base a judgement on that alone. Voltmeter check with engine running is only way to be sure. If its low then the alternator is to blame, regardless of state of charge light.
    HTH
    Regular Member badback's Avatar
    Runcorn
    The only symptom I had when my alternator packed in was no power steering, no battery light or any others. Luckily I was just turning onto my drive when it packed in.
  1. Vectra wiper problem - any advice appreciated - Vectra C
    By newbreed in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2011, 20:57
  2. Vectra 1.8 LS, big problem?
    By Mattyreid9 in forum Engine & Drivetrain
    Last Post: 5th October 2010, 12:28
  3. air con problem vectra c
    By stevenrwaller in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2010, 10:03
  4. vectra c problem help
    By beemerboy31 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2009, 23:39
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
